Question about Belkin Dual-Band Wireless A+G Desktop Network Card (F6D3000)
Belkin Dual-Band Wireless A+G Desktop Network Card (F6D3000)v2
Dave117
  • 134 Answers
SOURCE: Belkin Wireless notebook network card question
From another user on Fixya..
"you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled."
give it a try, might help. Rgds,
Posted on May 08, 2008
AvioriX
  • 689 Answers
SOURCE: Belkin F5D7011 wireless network card
Hi
You can download it from the link below (Free of Charge)
http://www.belkin.com/support/article/?lid=en&pid=F5D7011&aid=5391&scid=221
Good Luck
Posted on Jan 19, 2008
tom19511
  • 1601 Answers
SOURCE: Belkin wireless connection
scott:
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers1.gif.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones1.gif in the area and see if it helps.
Try going to the usb and the wireless adapter in device manager, properties. And make sure that the computer1.gif does not shut them off to save power.
Please let me know how you make out.
thanks
Posted on Jan 25, 2008
  • 54 Answers
SOURCE: Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Posted on Feb 05, 2009
  • 233 Answers
SOURCE: very short range
No this is not typical if the Network card and router are just one room away. However electrical interference and walls do impede the signal.
Try moving the Router around to see if the signal improves.
You can also adjust the antenna and pointing it in the direction of the Router.
1. Position your wireless router (or wireless access point) in a central location.
2. Move the router off the floor and away from walls and metal objects. (Such as Metal file cabinets)
3. Replace your router's antenna.
Antennas supplied with your router are designed to be omni-directional, meaning they broadcast in all directions around the router. Upgrade to a hi-gain antenna that focuses the wireless signals only one direction. You can aim the signal in the direction you need most.
4. You can add wireless repeaters. (just the room next door this would be a last resort if all else fails)
5. Change your wireless channel. You may find one that will transmit a stronger signal.
6. Reduce wireless interference
If you have cordless phones or other wireless electronics in your home, your computer might not be able to "hear" your router over the noise from the other devices.. To quite the noise, avoid wireless electronics that use the 2.4 GHz frequency. Instead, look for cordless phones that use the 5.8 Ghz or 900 MHz frequencies.
7. Update your firmware or your network adapter driver
Source:
http://www.microsoft.com/athome/setup/wirelesstips.aspx
Nice diagrams on this web page too.
(Couple items left off as these did not seem to fit your current situation)
Posted on Oct 06, 2009
Bought brand new belkin router still in ceellophane wrap.hooked it up.inserted cd installed softwarebut wouldnt let me get on line and register it.called belkin and they stated was outdated and no lon
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 05, 2013 | Belkin Computers & Internet
Belkin dual-bank travel router how can i set up in computer
The Pre-Shared Key is your wireless security password, in the form of a word, phrase or series of letters and numbers. The key must be between 8 and 63 characters long and can include spaces and symbols, or 64 Hex (0-F) only. Each client that connects to the network must use the same key (Pre-Shared Key).
The key can be found in 3 different places on your router. The first place is on the wireless security card that came included with your router, it comes taped to the side of your router and fits conveniently in a slot on the underside of your router for storage. The security key is also printer on the top right corner of the product label for your router. This is found on the underside of the router. Finally, you can also login to the routers configuration page to retrieve your wireless key. We have outlined these steps below.O keep reading http://www.fixya.com/support/r10611007-setup_belkin
Jan 24, 2013 | Belkin Dual-Band Wireless A+G Desktop...
I need a driver to my desktop card
http://www.wardrive.net/drivers/belkin just look for this site
Jul 31, 2011 | Belkin Dual-Band Wireless A+G Desktop...
Hey, I have a Belkin Dual-Band Wireless A+G Desktop Network Card, but I can't find the correct driver to download. I tried the f63000 but it still is not recognizing the Internet source...any ideas?
You tried this one?
http://www.belkin.com/support/article/?lid=en&pid=F6D3000&aid=6033&scid=223
How about this one?
http://en-us-support.belkin.com/app/answers/detail/a_id/499/kw/f6d3000
I did notice that there is no specified support for 64-bit versions of ANY OS,
and doesn't specify compatibility with any version of Vista or 7.
Try uninstalling any software and drivers you tried so far, then also remove the entry from Device Manager... THEN install one of the above drivers.
May 05, 2011 | Belkin Dual-Band Wireless A+G Desktop...
Since I purchased a Belkin N600 my download speed is about 30k/bps. My ISP says it's the N600. Help!!!
If you are wirelessly connecting you need to use a wireless card that supports dual band.
and then changnig the settings on the wireless card helps.
if you are wired the issue is with the router settings.
Upgrade the firmware on the router
see belkins website on how to do this:
http://en-us-support.belkin.com/app/answers/detail/a_id/4497
Apr 07, 2011 | Belkin Play N600 Wireless Dual Band Router...
No Signal Strength
You said that your wireless works fine with other computers. So i think the router must be working fine.
you can try to uninstall and reinstall the adapter.
Or upgrade the drivers of the adapter that will help you.
Click here for more info about the networking
Oct 07, 2009 | Belkin Dual-Band Wireless A+G Desktop...
Very short range
Source:
Oct 06, 2009 | Belkin Dual-Band Wireless A+G Desktop...
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Belkin Dual-Band Wireless A+G Desktop Network Card (F6D3000) Logo
95 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
