Question about Car Audio & Video
How to install a pioneer DEH-X55HD - Car Audio & Video
2 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Posted on Jul 09, 2009
How do i install a pioneer deh-1550 car radio
The installation manual is here
Pioneer DEH 1550 Installation Manual
PIONEER DEH-1550 INSTALLATION MANUAL Pdf Download.
https://www.manualslib.com > ... > Car Stereo System > DEH-1550 XU
View and Download Pioneer DEH-1550 installation manual online. DEH-1550; DEH-1550B. DEH-1550 Car Stereo System pdf manual download. Also for: Deh-1550b, Deh-3450, Deh-2450f.
[PDF]DEH-1550UB DEH-1550UBG - Pioneer
www.pioneer-latin.com/.../operating%20manual%20(deh-1550ub)-eng-esp-por.pdf ???? ???????? CD ?? ????? RDS. ?????? ?????? CD RDS. Espa?ol. DEH-1550UB. DEH-1550UBG. Portugues (B). Owner's Manual. Manual de instrucciones i ... PIONEER Service Station. Press to recall preset stations. Press to select the next/pre- vious folder. AUX input jack. (3.5 mm stereo jack). 6 Disc loading slot 3. O USB ...
How To - Understanding Pioneer Wire Harness Color Codes for DEH ...
? 6:05
https://www.youtube.com/watch?v=kR2MO2kwFug Nov 14, 2016 - Uploaded by pioneerelectronics
Learn about the Wire Harness Color Codes for Pioneer in dash receivers that do not have video screens. DEH ...
How to restore and reset your Pioneer DEH radio - YouTube
? 1:20
https://www.youtube.com/watch?v=_QyuVanWfLA Jul 26, 2016 - Uploaded by Five Star Car Stereo
in this video we show you how to restore your radio into factory default settings. ... to restore and reset your ...
Mar 24, 2018 | Pioneer Car Audio & Video
Kicker dx 250.1 class d monoblock amp has a fixed lpf at 80 hz 24db octave non adjustable. My car stereo is a pioneer deh-x55hd with the sub control set at 100 hz -6 slope unable to turn sub control off to...
Do you have the subwoofer amp connected to the pioneer thru pre amp connections; pre amp output of pioneer to pre amp input of Kicker amp. Page 10 of the manual explains how to adjust the subwoofer output. You can select the cutoff freq. that will pass to the subwoofer; The slopes don't match perfectly, but if you use the -12 slope , it should work fine.
Cut-off frequency:
50HZ
63HZ
80HZ same as kicker cut in freq
100HZ
125HZ
160HZ
200HZ
Output level:
24
to
+6
Slope level:
6
12
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X5500HD_OwnersManual112712.pdf
May 19, 2014 | Car Audio & Video
Pioneer deh-2300 wiring diagram please
here is the installation and user manual link see fig 4 installation manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-2300R/index.html
Cheers!
Jan 30, 2010 | Pioneer DEH-2300 CD Player
I NEED WIRING DIAGRAM FOR PIONEER DEH-P470MP
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4700MP/index.html
the wiring diagram is on page 5 of the installation manual
Cheers!
Oct 11, 2009 | Pioneer DEH-4700MP CD Player
Cant find a user manual that instucts use of the Pioneer DEH-P85BT. Have found and installation manual and have downloaded but need the instructions for use and functions !
User manual PIONEER DEH-P85BT google_ad_client = "pub-1682016597802119"; google_hints = "PIONEER, TV, Plasma TV & LCD TV"; google_ad_slot = "5978704237"; google_ad_width = 468; google_ad_height = 60; window.google_render_ad();
Download the complete
user guide (1540 Ko)
Need help, support, reviews, tips or troubleshooting for your PIONEER DEH-P85BT products ?
You may also download the following manuals related to this product:
May 06, 2009 | Car Audio & Video
Hi, i am looking for wire color codes for pioneer deh-p7200 car stereo?
hey , i believe the pioneer install manual will provide the color codes , this manual in multi lingual , but english is first in the list , its only like 2 or 3 pages . :)
pioneer deh-p7200
J5
Jan 20, 2009 | Pioneer DEH-P7200 CD Player
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Installing a Pioneer DEH-P77DH
You can download the manual from the link below: http://files-upload.com/files/461301/DEH-P77DH_install.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 26, 2007 | Pioneer DEH-P77DH CD Player
Car Audio & Video Logo
463 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
