Question about Acer Aspire 7230 7530 7530g 7730 7730g Upper Case & Touchpad W/ Fp
Acer aspire 7530 overheating
My Acer Aspitre 7530 overheats and shuts down, the heatsink and ventilation systems are fine, the CPU reaches 95 centigrades when running in high performance mode. Is it perhaps that this laptop wasn't well designed? Thank you for your input
  • 788 Answers
SOURCE: ACER Aspire 5720 overheat problem?
Try to keep as much ventilation under the laptop as possible.
You can pick up a can of power spray and blow out the unit yourself or have a pro. do it for you.
Dust and lint play a deadly part in overheating with laptops.
Walmart has Ventilation trays in which the laptop sits and is cooled by forced air from underneath.
Make sure the direction of air flow is the same as your laptop.
You dont want to push air into a output vent.
Posted on Aug 30, 2009
  • 55 Answers
SOURCE: ACER Aspire 5050 Overheats
You can do it yourself, but I do not recommend it,
I would first try buying a cooling pad for your laptop to see if that resolves the problem.
Posted on Mar 14, 2008
  • 92 Answers
SOURCE: acer aspire 5920 laptop is not shutting down.
There Are 3 Fixes For This Problem, 1 Is To Insert Your Windows XP CD And Boot From It Then, Say Repair When It Asks And It Will Put Your Shutdown.exe File Back On UR PC.
The Second Way Is To Download Win XP Utilities And Click Repair Windows Files.
The Third Way Is To Run Some Program Which I Forgot The Name Of That Checks Your Files Are Intact. That Should Be In Control Panel And Is Also On Vista.
Also If You Have Vista You Can Put In Your Vista DVD And Click Repair This Computer Or Whatever When It Asks.
Posted on May 07, 2009
SOURCE: Laptop overheating/Bad ventilation design.
I just fixed this with my daughter's laptop Acer Aspire 7720. The prolem was with lint covering inner side (facing cooling fan outlet). To fix:
- open the big cover on the bottom for the memory slots - well it covers everything: processor(s), memory clots etc.
4 screws, the cover also held by snapping little plastic tabs, do not be afraid to open but be rather carefull, do not just yank it open, you will see the fan facing back of the laptop in the corner, it suppose to blow through the heat sink.
- remove the fan, 3 screws, the screws are very little so be careful, you will see the inner side of the sink more likely coverd with lint, dust etc.
- carefully remove using tweezers and blow using canned compress air dust remover.
- assemble back in reversed order.
without removing the fan it is not really clear what it is I almost accidentaly saw it...
do not be afraid to do so you just need small screw driver. magnetic screw driver helps to handle the screws but be carefull with it as some components may be sensitive to magnetic field...
this did the trick for me I hope it works for you. please spread the word as I saw many posts about it in forums...
Posted on Oct 04, 2009
  • 10406 Answers
SOURCE: laptop shuts down
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job", to remove the dust, because the dust is acting as a layer of insulation, trapping heat inside your computer.
Reload the battery.
Connect the AC power.
Start your laptop, and check that the fans inside the notebook computer are pushing air out of the exhaust-vents. If not, the fan(s) have failed, and you need a professional computer technician to disassemble your computer, and fix the fans.
Posted on Jul 16, 2010
Got an ACER 7530G with a thermal isue. After some time it shuts immediately down. Seems to be a thermal processor problem. Fan is running, no dust inside. Processor temperature is between 52deg. C and 66...
If the fans are spinning then you need to take off the heatsink and ensure that there is paste between the heatsink and the CPU (its a golden or silver color normally). If not, go buy thermal paste.
If there is paste, then the heatsink was not placed properly on top of the CPU. Even if 3 corners are properly inserted and only one is not properly done, this can certainly cause overheating.
Oct 13, 2013 | Acer Aspire 7530 7530g 7730 7730g 7730z...
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
Acer Aspire 7520, running windows Vista, keeps overheating and shutting down. It is fairly new - less than a year old. Does not run for much more than 20 minutes before shutting off. It was purchased in...
Sounds like there is dust where the cpu fan is and its blocking the ventilation path in the laptop. If you can take apart the laptop to expose the fan, I would make sure the fan is free of debris. Clogged CPU fans will cause the laptop to overheat cause the air has nowhere to go.
If you do that and the laptop is still overheating then the motherboard is going bad unless your not using the correct charger for it. If you use a charger that puts out more voltage then whats needed then that could cause the laptop to overheat so you might need a new charger.
Apr 15, 2010 | Acer Aspire 7520-5185 Laptop
Acer laptop goes off after 30 minutes exactly. wont come if i try immediately but after about 5 mins comes on when I power it. help
you have set ur computer to sleep or hibernate after 30 minutes of inactivity. you can customize this in you power setting.
Control Panel-> Power Options
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Blank screen. Won't turn on.
You could have an overheating problem. The CPU shutsdown when it overheats and won't boot up again until it has cooled down. Check the CPU fan and heatsink assembly. The fan may have stopped spinning or spins slowly and the heatsink is clogged with dust.
Remove the dust and replace the fan if it is faulty.
Sep 11, 2009 | Acer Aspire 5735 Notebook
Automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Aug 01, 2009 | Acer Aspire 5315 Notebook
Cpu overheats
the alternative but not the best solution is to buy one of those usb powered laptop chillers
Robert
Jan 27, 2009 | Acer Aspire 7720 Notebook
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Over heating
I would suggest you to check the heatsink and cpu fan,
it could be dirty, if it is dirty, clean it and it should work fine.
To see heatsink and cpu fan, open 4 screw on the back of your laptop.
remove the cover, remove the fan screw (3), remove fan,
remove 4 screw on the cpu heatsink, remove the heatsink.
if your heatsink and fan are clean, it could be something else cause the shut down.
in this case you should send it for repair.
Oct 07, 2008 | Computers & Internet
Big problems
start the system hit delete or F2 to enter setup load system defaults then exit saving changes.
if it didnt work
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Nov 16, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 7230 7530 7530g 7730 7730g Upper Case & Touchpad W/ Fp Logo
326 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
