Question about Life Science Bionet Cardiocare 2000 12 Channel Ecg
BIONET ECG 2000 CHANGING FROM SPANISH TO ENGLISH
Changing the language on the 8L next book tablet
Click on the icon that looks like small square dots. from there look for Settings. Click on Settings > Then scroll to find Language and click here. Then find the English and set it to English.
In Spanish, Settings = Ajustes and English is Ingles
Jul 30, 2016 | Tablets & eReaders
All leads are on the right spot, why it's not generating result - it says Limb lead disconnected
The cable may be broken inside its insulation. Or... there may be a problem with your skin on that limb - try the other arm, or use your legs.
Jun 23, 2014 | Life Science Bionet Cardiotouch 3000 12...
I have a problem in ekg bionet cardiocare 2000. When I test it, the led of ready does not turn and therefore there is no signal measure. I changed the entire cable and the problem continues. Thanks
If you haven't solved the problem yet, most likely you will have to send the unit in for repair. When you first power up the unit the system goes through a self test. "light on then off then on again"
Mar 07, 2013 | Life Science Bionet Cardiocare 2000 12...
Cardiocare 2000 (Bionet) machine won't print full page!
hi, if i want to start running unit. after that always on display data error, plz turn off. why? what can i do for that? thax
Jan 22, 2013 | Life Science Bionet Cardiocare 2000 12...
EKG / ECG Machines
The noise is because of the mechanics of the printer you have to open it and you will find one dashly is partially broken or not fixed so change it or fix it.
Oct 02, 2012 | Life Science Bionet Cardiocare 2000 12...
Hi,i have probleme in ekg bionet 2000, when i test it without electrods and start printing,,at first it print signal normal but after a few seconds he show a huge and large line with lot of noises in...
We are experts in fixing the Bionet 2000 ekg machines.
1) Is the machine plugged in to the wall when you are getting interference? If so, unplug it
2) Your patient cables may be malfunctioning, do they look damaged?
3) Are the electrodes expired?
4) make sure and prep the patient
If you are still having issues, send the machine to us at Discount Cardiology. We will look at it for free and let you know what is wrong with it. You then would have the option of fixing the machine or having it sent back to you.
Discount Cardiology
www.cardiologyforless.com
Jan 30, 2012 | Life Science Bionet Cardiocare 2000 12...
My ECG machine is not functioning because of open signal is alert all the time when i was start up the ECG machine
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
Aug 05, 2011 | Life Science Bionet Cardiocare 2000 12...
After changing my daughter's ds back to english, why is the game still being played in spanish?
Some DS games are only in one language, may it be French, Spanish or English. It's not all games, unfortunately, that have the ability to be multilingual.
In your case, it's a Spanish game which hasn't been translated to English. Therefore, changing the DS's language will have no effect on the game: it'll still be in Spanish whatever you do.
The only way to have the game in English is to have an English version of the game.
Jul 08, 2011 | Nintendo DS Console
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
Don't know the difference between a one channel and three channel
Bionet CardioCare 2000 Interpretive EKG for around $1200 is a good user friendly model...
below is a link to shop for new & used machines
http://www.cardiacdirect.com/index.php?page=products&id=1
I hope this is helpful.
Jan 03, 2009 | Schiller Cardiovit At 1 Ecg Machine
Life Science Bionet Cardiocare 2000 12 Channel Ecg Logo
53 people viewed this question
Top Life Science Medical Experts
Electro Med Services...
Tom Chichester
ka4iup
ka4iup
Are you a Life Science Medical Expert? Answer questions, earn points and help others
