Question about Gateway 5200XL PC Desktop
Adding DDR RAM
Can I use Server ram instead of regular ram. My PC uses PC2100 184 pin CL2.5 2.5V. I have a PC2100 184Pin Server Grade Stick. Can I Use this in my PC being it is server grade?
  • Joe Neff Jan 21, 2009
    It is A Emachine Desktop PC Model T1742 for Home or Office Use
  • Joe Neff Jan 27, 2009
    Thank you for your help. I was going to add a sdram memory to my pc and I found out you cannot add sdram with ddr memory nor can I use server grade....thanks again!!!!!
  • 32 Answers
While you likely can use the RAM, be careful. Some printers use proprietary memory with designs which could mess up your notebook. Contact the printer manufacturer and ask if their memory is standard or proprietary.
The cost of RAM today doesn't merit you risking the entire notebook for memory that can mess the computer badly.
Posted on Jan 21, 2009
  • solutions4u Jan 21, 2009
    Emachine is a manufacturer of PCs with which I personally have experience. I learned with my first Emachine that they have a tendency for proprietary hardware design. After my first purchase I refused to purchase others from Emachine for this reason.
    It is reasonable to conclude that the memory would match. To verify, as best as possible I will refer you to:
    http://crucial.com/.
    You may either use the Scan my System button or Memory Advisor Tool to asssist you in your decision.
Can an old HP Workstation xw8000 Computer that is currently using 512 RAM (PC2100 registered 184 PIN ECC DDR SDRAM DIMMs) be upgrade using 4GB Kit (2 X 2GB) PC2100 Registered 266MHz 184 pin DDR SDRA
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
Mar 11, 2014 | Dell W4201C 42 in. Plasma HDTV
Can i use a ddr2 400mhz ram on a GA8ipe1000 motherboard?
According to the Gigabyte website
http://www.gigabyte.com/products/product-page.aspx?pid=1863#sp
that motherboard only has DDR slots (4 of them), so, no you cannot use DDR2 RAM modules.
If you do manage to make it fit, the pins won't line up because DDR can be 184pin or 200pin, and DDR2 can be 214-pin, 240-pin, 244-pin.
Since your memory slots or only DDR, there is no way that the DDR2 would make the connections that it would need to make in order for it to work.
I hope this helps! If not, please comment back and let us know!
Dec 30, 2010 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Can i use DDR2 RAM instead of DDR1
YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
You Cannot use both types of ram memory in the motherboard, at the same time.
(BIOS will only recognize one type at a time)
NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
92 on Each side,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the above photo to enlarge)
DDR2 Sdram ram memory modules have 240 contact pins.
120 on Each side.
Sep 04, 2010 | HP Computers & Internet
Is their a special make of memory card, ie: ddr
According to: http://www.shopping.com/xPF-VIA-MB-FOXCONN-VIA-KM400A-400M01-G-6L-R
this motherboard has 2 slots for DDR (184pin) RAM,
and supports a maximum of 1GB of RAM per slot.
Note that DDR RAM comes in 3 speeds: DDR266 (slowest), DDR333, and DDR400 (fastest).
Buy the fastest RAM -- if the motherboard cannot run the RAM at "full" speed, the RAM will automatically slow itself down to a speed that the motherboard will support.
Sep 15, 2009 | Foxconn 400M01-G-6L Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
Want to buy more RAM..
Your dell dimension takes DDR ram. These are the specs:
Supported pin types: 184 pin DIMM (regular desktop DDR ram)
Supported memory types: DDR PC2700 or DDR PC3200
Supported speeds: 333mhz or 400mhz
Supported stick sizes: 128mb, 256mb, 512mb or 1gb.
MAXIMUM MEMORY ALLOWED: 2gb (2 x 1gb sticks)
If you buy two of these you will max out for ram and give you the best performance::
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1558844&CatId=1600
Dec 24, 2008 | Dell Dimension 3000 PC Desktop
I want to up grade my RAM
I'm afraid the highest frequency ram for your laptop is DDR 333. The highest capacity is 1024MB DDR333, 333MHz, PC2700, 200 pin SODIMMs.
Nov 18, 2008 | Dell Latitude D600 Notebook
Pc will not boot
Make sure the ram is seated properly and in the slots correctly. If you are using more than one chip, use only one to start and then add any others yoiu may have. I think you will find a ram slot is craked or the chip is inserted backwards. You really cannot damage a M/B by adding DDR instead of DDR2. It really just about the bus path and bus speed. Double check our work.
Sep 26, 2008 | Biostar K8M800 Micro AM2 Motherboard
Adding more memory to my desktop
if the pin placement is some thing like this
...... ............... ............................... its a SD RAM
if it is like this
.......................... ............................ its a DDR RAM
if it is a SD RAM or DDR ram just get it by the a computer store
there are only 3 types avalible for old computers SD or DDR or RD..... you dont need RD RAM it would be SD probably ....just look at a pin allignment.....
Dec 10, 2007 | Computers & Internet
Gateway 5200XL PC Desktop Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
