Question about Master Heaters Master Airbrush Model G75 Airbrushing System with AirBrushDepot TC20 Tankless Air Compressor
HOW TO REBUILD A MASTER G34 AIRBRUSH
HOW TO REBUILD A MASTER AIRBRUSH BRAND MODEL G34
2 Suggested Answers
SOURCE: Is there an instruction manual for the Master
i am not getting the paint to spray from the paint cup please help
Posted on Nov 08, 2012
How to turn up the psi
off the memory - on this particular model you have knob just before the valve and indicator, lift it up and turn clockwise to increase pressure and anticlockwise to decrease it.
Apr 04, 2014 | Airbrush-Depot Master Airbrush Model G23...
Won't spray
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Jan 23, 2013 | Airbrush-Depot Master Airbrush Model G23...
CANT GET PLUNGER ORING BACK INTO MY G22
Hi!
Here's a very detailed guide for this airbrush. I'm sure you'll find your answer:
https://sites.google.com/site/donsairbrushtips/master-g22
Jan 06, 2013 | Airbrush-Depot Master Airbursh G22 .3mm...
Cant get plunger o ringback into my master g22
Please take a look at this guide, it is detailed:
How do I connect a badger airbrush hose to a Airbrush Depot TC20T compressor?
Airbrush Depot compressor should be a 1.4NPT which is the most common- Badger makes an adapter for this size to their hose fitting. That fitting should be available from many sources. Badger did/does use a couple of sizes so make sure you know which model of brush you have.
http://badgerairbrush.com/Acessories_4.asp is the piece.it is at the bottom of the page.
If nothing else, it should be available through Walthers http://www.walthers.com
Feb 14, 2012 | Master Heaters Air Tools & Compressors
Need manual...part description to re build airbrush
Try this link!:
http://www.tcpglobal.com/airbrushdepot/itemdetail.aspx?itemno=MAS+P70-MAJOR
G77 is a set which includes G76 Airbrush!
These store sells the major rebuilt parts kit for the G76!
Hope this 'push' helps!
Oct 12, 2011 | Master Heaters Model G77 Airbrushing...
My daughter bought a master airbrush spray tanning system - g70 - with no instruction manual. air is coming out but no tanning solution - any assistance would be greatly appreciated
I got the exact same kit as a Christmas gift (I am a cake decorator). I have asked the supplier how to fix this problem, but they only told me to google airbrush videos. I'm not sure how to connect all the hoses to the compressor and the external paint cup. Been struggling for weeks to find info online. I also have a G34 and that works fine (but it only holds a miniscule amount of paint). Good luck, hope you manage to get an answer.
Jan 16, 2011 | Master Heaters Master Airbrush Model G75...
Is there an instruction manual for the Master Airbrush Model S68?
Dec 15, 2010 | Master Heaters Master Airbrush Model G75...
G22 airbrush is blowing air out of the cap and non is comming out of the tip wtf? checked everything, their is air comming out of the nozzil but no paint.. the cap keeps blowing off and the pain getting...
It sounds like you have a dirty tip. It doesn't take much to stop the flow to the tip. You need to take the tip completely apart to give it a proper cleaning. Just soaking it won't do.
Hope this helps but if not let me know and I'll try and trouble shoot further.
Jun 08, 2010 | Master Heaters MASTER AIRBRUSH MODEL G22...
Master Heaters Master Airbrush Model G75 Airbrushing System with AirBrushDepot TC20 Tankless Air Compressor Logo
259 people viewed this question
Top Master Heaters Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Master Heaters Air Tool and Compressor Expert? Answer questions, earn points and help others
