Emailair remote to celcius - Heating & Cooling
Need new remote
Most "generic" remotes can be programmed to work on most brands. Have a look at the back of the packet the remote comes in, it will show which makes / models the remote can be programmed to. In a lot of cases, the generic remote is a lot cheaper than a genuine one however some functions may not be accessible. IE/ Sleep or timer function. Dick Smith electronics or a general electronics store may have them or an air conditioner parts outlet will have them such as Heatcraft, Airfridge, Airspares etc (In Australia)
Mar 29, 2014 | Heating & Cooling
How change farenheit to celcius, remote control unit model ar-rah2u
Turn off the remote, hold down the temp raise button until you see the F or C appear, hit the temp raise button again to select F or C, turn on the remote.
Mar 28, 2012 | Fujitsu Heating & Cooling
How do u change the fahrenheit scaling to celcius scale in the voltas ac... via remote control
Voltas remote..instructions are given behind the remote.
Off remote.
Press mode and - .
chages d unit of temperature.
Sep 16, 2011 | Heating & Cooling
How do I change my A/C temperature from Farenheit to Celcius on my Panasonic remote control?
try to inspect your remote it has a button of adjusting farenheit to celcius or try to see your users manual.
Feb 23, 2011 | Heating & Cooling
How do you switch from farenheit to Celcius on the remote of my Panasonic Inverter CS-S12KKQ
Press and hold TIMER (V) down button located under 2, for 10 seconds.
Feb 07, 2011 | Heating & Cooling
I cant get cooling from my air con,model-emailair WS066H,but I do not have a remote control for it,can i control it manually.
Only in some models, there is an option to operate manual. Check near indoor display. If there is button press it. But you can't change temp setting and mode as you like.So, It's advisable get new remote.
Dec 29, 2010 | Heating & Cooling
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
