Question about American Standard Kitchen Faucet Colony Soft 4275.551 099 Polished Brass Tw...
American standard 6425f leaks under base - American Standard Kitchen Faucet Colony Soft 4275.551 099 Polished Brass Tw...
frcs68
  • 1605 Answers
SOURCE: how do you change the cartrige for easy touch american standart k
unscrew a alen screw on the underside of the handle.
unscrew the cap that is holding the main body of the fixture.
pull up the fixture.
install in reverse order.
Posted on Jan 06, 2009
  • 297 Answers
SOURCE: American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Posted on Jul 22, 2009
  • 297 Answers
SOURCE: repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
SOURCE: i have an american standard pullout disc faucet
Chuck,
Definitely change the O ring, and ensure the disc is installed properly, as well as ensure there is no debris on the disc. It sounds like the O ring was torn during the first procedure. Good Luck.
Steve
Posted on Oct 12, 2009
  • 25 Answers
SOURCE: Water leaking down sprayer hose under sink.
They didn't put the attachment on correctly. Look at the directions for the sprayer. It's a black little piece with grey clips. U need to put it on correctly so it seals. That should stop the leak!
Posted on Jan 04, 2010
My american standard model 4040 faucet is leaking at the base of the spout.
I checked online at www.plumbingwarehouse.com/american-standard-kitchen-faucet-hamilton-4040. There is a diagram that shows a seal kit that probably needs to be replaced. The diagram is really good and shows a complete breakdown of your faucet. I hope this helps.
Apr 10, 2015 | American Standard Plumbing
American Standard Jasmine 3821.834 leaking where spout enters base
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
Mar 29, 2011 | American Standard Jasmine 3821.834.295...
When dishwasher is running, water leaks under base of our American Standard Colony model soft two-handle kitchen faucet into cabinet beneath sink
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Jan 16, 2011 | American Standard 4275.550.002 ColonySoft...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
I have an american standard pullout disc faucet which is leaking. I replaced the disk. Now it is leaking more than befoe from the base. What should I do? Is it the o seal at the bottom? chuck
Chuck,
Steve
Oct 11, 2009 | American Standard Kitchen Faucet 6310 020...
American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
Jul 13, 2009 | American Standard 4275.550.002 ColonySoft...
Repair leak on jasmine faucet - American Standard
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
American Standard Kitchen Faucet Colony Soft 4275.551 099 Polished Brass Tw... Logo
49 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
