Question about Whirlpool GLT3014 Gas Cooktop
All burners won't ignite when knob turn to LITE
Hello, first time posting here. Hope someone can help me. The burners will not ignite automatically when I turn the knob to LITE. None of them work. However, I can use a lighter to manually light it. So, the gas is there, and we checked, the electric power is there and working. I have researched a bit on the web, I think it is the spark module that needs to be replaced, sound right? My problem is that I don't know how to access to the spark module. It is a gas sealed burner cooktop with glass surface. It is sitting on the counter top and under the counter, there is my oven. Do I need to remove the oven to get to the bottom of the cooktop? Is this a job that is recommended to be done by the professional or can be done by ourselves? Husband thinks that I should just keep using the lighter to manually light the burner. I am not ready to give up, just yet :) Would appreciate any help or suggestions.
How lite a eletric gas oven when power lite dont work
Posted on Sep 16, 2008
  • 40 Answers
I greatly appreciate u to do all this checking usually house wifes ask the husband to do all this jobs u can replace the whole assembly from the burner and put a new one for replacing u have to unscrew the back side of the burner it can be done with a spanner or screw driver u should have a nose player or a set f spanners to unscrew the unit after opening the burner u wont get time to get for all this things so first make all the tools ready and start to work i am sure u will make it workingggg
Posted on Jul 03, 2007
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
Hello, My Creda cookertop ignition system has a problem . There are 4 burners on this CT. 2 diagonally across burners cannot ignite when their knobs are activated but they show sparks of ignition when the...
(1) Get Naval Jelly (Rust dissolver) and apply on the igniter and than see if everything is fine.
(2) Check the connections from the knob to the burner. Probably have a leak. Replace the wire from the knob to the burner.
Feb 02, 2011 | Cooktops
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
Ignitor does not spark on first turn as stated in manual. I have to turn the knob past "lite" before flame comes on.
Is it just one burner knob that does that are all of them? If it is just one then the igniter switch built into the burner knob might be out of alignment or loose. This happens most of the time due to a cracked switch housing(made of plastic). This can also happen if the actual burner knob is cracked and/or loose. If all the burners do this then it is just the way the cooktop works. The best way to get the burners to light is by slowly turning them on until they light and not pay attention to the "light" mark. You might need to turn it just past the "light" mark for the burner to come on.
Jan 18, 2010 | GE 30 in. JGP326 Gas Cooktop
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
Clicks occur in "low" position instead of "lite" position
Sounds like the switch electric sending unit needs to be Ither cleaned and dry good or replced. It's not hard at all, They are located under the knob switches, you will have to remove the knobs and the top cover, they look like a small square box wit a hole in the middle with two wires on the sides, just unplug the wires and lift the box off the switch rod. cleane them and dry them good and put them back.......that should do it.....Good Luck
Eddie Rentas
Tupper LAke NY
Jul 16, 2008 | Cooktops
Automatic Eletric Ignition stopped working
It's is normal for the ignitors not to work when wet, once they dry they should work. The best thing is to check the electric sending unit, they are a small white kind of square that goes on the switch, just lift the knobs and take the cover of the switches and you should see the sending units righ on the rod that hold the knobs, they have to small wires attached to them, It seems to me that thats were your problem is.
Do you hear the click clik when you put the knob on LITE??
May 19, 2008 | GE 30 in. JGP336 Gas Cooktop
Whirlpool GLT3014 Gas Cooktop Logo
560 people viewed this question
Top Whirlpool Cooktops Experts
vince
Whirlpool
Whirlpool
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
