Player's tray has jammed.
I have one PIONEER DVL V-888 MULTI PLAYER (DVD LD KARAOKE). Now the tray has jammed. How to open it?
  • alan439 Feb 09, 2009
    Thank you!
    I tried many times to reset the unit according to your instruction, but, end up the player blew the fuse. After I replaced the fuse, the same thing happened again. Now the player is dead.
    I think the moter which drove the disk tray was jamed. Could you let me know how to physically remove the disk tray? Do you have a manual for disassembling which I can follow?
    Thank you again.
  • alan439 Feb 13, 2009
    I knew where to get manual, but I don't want to get whole manual, as I just fix this player for free. I just need a quick solution. Could you let me know how to open it basing on your experience. I feel it is a mechanical issue which you may know well and have a lot of tips. As this player is so old, I may throw it away if it is not easy to fix.
    Thanks in advance.
  • 10,594 Answers
You can buy service manual having exploded views and part details to follow how to disassemble and assemble cd mechanism in this unit.
Posted on Feb 12, 2009
  • Shahid Electronics
    Shahid Electronics Feb 12, 2009
    HERE you can buy service manual for $15
    Shahid Electronics Feb 13, 2009
    Please find screws at sides and rear of unit, unscrew and take off top cover.
    You will see cd/ ld disk tray, under this tray there is loading mechanism which needs to be realigned.
    Related service manual will let you know how to set timing of loading gears or alignment etc. So thats why I gave you link to have service manual. Attempt to repair unit without manual usually ends upon more damage.
Hod do I factory reset my karaoke player
CAVS USA User Forum - H...
How do I reset my player to factory settings? ... How to make a karaoke songbook file from an external hard drive on a 203G USB After preparing the external ...
CAVS USA User Forum - W...
Reset the players to factory defaults. *Defaults will ... Why don't I ... Why will my new [model] karaoke player not play SuperCD+G discs? SuperCD+G discs play ...
Supersonic SDAT SC-25 DVD/Karaoke Player Factory reset ... > ... > Supersonic SDAT SC-25 DVD/Karaoke Player
Supersonic SDAT SC-25 DVD/Karaoke Player, factory reset button related issues. ......reset my pioneer dv 490v to factory setting here is the link to your manual: ...
Acesonic DGX-109 USB Multi-Format Karaoke Player with ...
Dec 06, 2015 | Televison & Video
Flash Sum
  1. Have you tried cold starting it; disconnect it completely from the mains for ~10 mins, then reconnect and try again.
  2. It is probably a problem with the EPROM or the CPU. You could try resetting the software by holding in the STOP button while turning on the power to the unit. If that doesn't work it sounds like the EPROM is corrupt or the CPU is bad.
Nov 11, 2007 | Pioneer DVL-V888 DVD Player
I insert disc, but after a little while, disc ejects without even playing. Help!
happen to all disc?
if so, check the 'home' sensor for the tray. need to open up and take a look.
Jun 14, 2014 | Pioneer DVL-V888 DVD Player
Pioneer DVL-700. Unit Plays LD Discs & CD's fine but will not play any DVD Videos.
The dvd's are not spinning up correctly. If the belt inside is worn this will cause cd's to play but dvd's fail. open up and replce belt (small black rubber running on motor)
May 11, 2011 | Pioneer DVL-700
You need to remove the cover and expose the area where the motor sits close to the front, you will find a broken belt, replace that, if you can't get to the screw to remove the assembly, use your fingers or screwdriver to turn the cog so that the drawer is manually opened. make sure power cable is unplugged first.
Jul 26, 2008 | Pioneer DVL-V888 DVD Player
Disc Tray Won't Open
Sounds like a belt is slipping.
wont open, wont close, makes clicking/grinding noises etc.
Jan 25, 2008 | Pioneer DVL-909 DVD Player
Pioneer DVL-919 DVD door does not open
You can also try flipping the player upside down and shaking it a little. I bought a DVL 909 and when it arrived the tray wouldn't open. The seller told me to try that, and it actually worked. I wouldn't recommend shaking it quite so much as this video shows... but it does show that it can work.
Dec 14, 2007 | Pioneer DVL-919 DVD Player
DVL-V888 disk tray
you will have to take apart and see if you can push the disk into position other wise have to take apart tray system and remove disk.
Dec 03, 2007 | Pioneer DVL-V888 DVD Player
Disk Tray won't open
is there a tiny pinhole to push in a paper clip to eject the tray?
Jun 03, 2007 | Pioneer DVL-V888 DVD Player
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
