Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer is a front loader approx year 2000 maytag. dryer wont turn on. already tried flipping breakers
  • 979 Answers
Check the wiring in the back to see if any wires are burned off. There is also a thermal fuse under the top that may be bad. You can check it and see if it is bad. I bet, however, the problem is in the wiring. The plug that goes into the wall may have a wire that is burned off as well.
Posted on Jan 21, 2009
MY MAYTAG FRONT LOADER DRYER STOPED WORKING WHAT TO DO
It could be anything from the start switch to the timer or the motor itself. Did you check to see if the circuit breaker tripped?
May 29, 2012 | Maytag Dryers
My dry quite working after my was work in electric box he was flipping power on and off
Your dryer is a 220 appliance and should be on a circuit all by itself. Are the items in your circuit box labeled (Lights? kitchen, etc.) One should be labeled "dryer". If you cannot locate one that is labeled for your dryer, Check out the position of the circuit breakers. If the dryer breaker is turned off it will be in the oppoite postion of the others.Caution: DO NOT do what he did and begin flipping breakers! If your dryer breaker is in the off position,is you should be able to flip it back on. Before you do this, have the dryer turned off.
If this does not work, unplug your dryer and leave it unplugged for 5 minutes or so, so that the dryers' operating system can reset itself. Then try turning it back on.
Dec 16, 2010 | Maytag Dryers
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
Old (approx 30 years) gas dryer. It's been great.
The fron comes off. Two screws located toward the bottom front (where the front panel angles in) hold the front on. Then you need to remove the front bulkhead/duct work.
Putting the belt on the idler pulley is the trick. If you get this far and need more help, let me know.
Vic
May 09, 2009 | Dryers
Dryer wont turn on
it sounds like the door switch or main fuse has blown,check the door switch,click it in and out to see if it has the clicking sound,if not replace,you can check the main fuse by removing the back panel,it is located on the blower box,let me know-mike
Mar 02, 2009 | Whirlpool LER4634J Electric Dryer
MY MAYTAG DRYER DOES NOT WORK WHEN I TRY TO START IT. THE LIGHT TURNS ON WHEN I OPEN THE DOOR HOWEVER. THE DRYER IS 4 YEARS OLD.
try this first:
  • turn off the dryer circuit breaker in the house then turn it back on. sometimes the dual breaker will trip on only one side leaving you with a non functioning machine that seems to have power.
  • also check the door switch and make sure it is clicking when you slowly close the door.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 04, 2008 | Maytag Dryers
Maytag frontload dryer
hi THE THERMAL FUSE IN THOSE DRYERS CAUSE THIS PROBLEM rEMOVE THE FRONT PANEL 2 SCREWS ON FRONT AT BOTTOM REMOVE . THERMAL FUES IS LOCATED ON THE VENTING TO THE LEFT OFTHE ELEMENT .THANKS THEAPPLIANCE DOC
Jun 22, 2008 | Maytag PYE2300AY Electric Dryer
Maytag Neptune Electric Dryer
pf = power failure
do= door open
the dryer is tripping the breaker because your house wiring is probly not up to snuff, or you have a bad breaker. nothing you are saying sounds like a dryer problem, but could be a big issue with house (could be very bad, could cause fire)
May 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag model sde305dayw
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
