Question about Rapoo H3050 2.4GHz Wireless Headset with Bulit-in Microphone, Black
My headphone will not connect to the usb - Rapoo H3050 2.4GHz Wireless Headset with Bulit-in Microphone, Black
Windows xp - ms bluetooth adapter dongle - motorola s305 headset
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity.
Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection.
PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones.
Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter.
Wireless headphones require power to function.
Many wireless headphones come with a charger base.
You need to charge your headphones before you attempt to connect them to your PC.
Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC.
Connect the transmitter to your PC.
The transmitter may connect via the PC's headphone jack or USB port.
If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter.
If the transmitter connects via USB, you will likely need to install software to use your wireless headphones.
If your wireless headphones are Bluetooth-compatible, continue to the next step.
Pair your headphones via Bluetooth to your PC.
If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle.
Turn on your headphones and open the Bluetooth software on your PC.
Scan for Bluetooth devices from your PC.
Your headphones should appear.
Select the headphones and follow any further instructions to complete the pairing process.
Test the headphones.
Pick out a song or a video and play it on your PC.
Connect your wireless headphones and verify that you can hear the audio.
Find the volume controls on your headphones and adjust them to make sure the volume changes correctly.
If your headphones are not functioning properly, verify that the headphones are turned on.
If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC.
Recharge your headphones when you are finished using them.
To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them.
If the headphones are battery-powered, be sure that you always have spare batteries on hand.
Jul 18, 2013 | Microsoft Bluetooth v2.0 USB Dongle...
Tip
How do I Wire a USB Cable to a Stereo Phone Plug
<p>In general, the audio devices use audio cables such as RCA stereo headphones, or telephone cables, connection to other devices. In case you need a USB device to a stereo phone plug, you should use a single adapter cable to connect the USB cable will convert to a stereo phone. <br /> <p><br /> <p>1. Connect the USB end of the headphone adapter to the USB port of your audio device. <br /> <p><br /> <p>2. Connect one end of the headset to your male cable to the headphone port of the headset USB adapter. <br /> <p><br /> <p>3. Connect the other end of your headphone male to male cable to the headphone port of your stereo plug. Now you can connect to any port to connect to stereo. <br />
on Aug 05, 2011 | Cell Phones
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
No sound from headphones. Speakers work. Win7
Please clarify, Where is the Headphones connected? Front or back? if you tried it on the Front port without success, Plug in the speaker jack to the port where you did connect the Headphone and verify it's working or not. You can also try the headphone on the port where the speaker is connected.
Awaiting.
Nov 03, 2010 | HP Pavilion m7480n (882780389410) PC...
My laptop sounds from both the speaker when i connect headphone.
First go to control panel, sounds and audio devices
go to the audio tab and make sure that your usb device is selected for audio playback
then, unconnect the headphones and restart your computer
after restarting, connect the headphones and Speakers , it should work
May 04, 2009 | Computers & Internet
Dell GX280 Dextop: Very Low volume on Headphones
Are these USB headphones? If so, you must install them first and let the Device Manager confirm they are properly installed. Next, go to sound properties in control panel, select the headphones, and crank the volume within Windows. Finally, crank the volume controls on the headphones themselves. If they are not USB headphones, then the same sound jacks that allow speakers to be connected should allow the headphones to work.
Mar 21, 2009 | Dell OptiPlex GX280 PC Desktop
Is it possible to use regular headphones on your htc8900 that are not blue tooth if so how do i program it
If you use an adapter to convert the mini usb connection to headphones you can use it otherwise you will need headphones with the usb plug or a bluetooth set. I find most of my Tilt accessories on EBAY.
Mar 09, 2009 | HTC Tilt 8900 Smartphone
Dell inspiron 1520
Try uninstalling the software, then re-install it again and only plug the headphones in when asked to do so, this will enable the program to pick the headphones up and install the correct driver, if windows picks it up as new hardware and tries to install the drivers for it then it will not work correctly.
What version of vista are you using 32 or 64?
Nov 21, 2008 | Dell Inspiron 2200 Notebook
Logitech headphone
No it's NOT a problem with your mainboard nor your USB it's the headphones that are ****! I am a tech, bought the Logitech headphones same problem... I try them on 3 different laptops and 2 other PC's and the problem follows the head phones... Simple solution... Don't buy Logitech. That's how I solved my problem. :o)
Apr 22, 2008 | Logitech (9804090914) Consumer Headphones
Rapoo H3050 2.4GHz Wireless Headset with Bulit-in Microphone, Black Logo
26 people viewed this question
Top Rapoo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rapoo Audio Player and Recorder Expert? Answer questions, earn points and help others
