Kindle fire buzzing noise
Wont turn on or off , when charging light goes back and forth from green to red. not making contant humming type noise
SOURCE: TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Posted on Mar 27, 2008
SOURCE: humming noise & color changes picture flashes from red to green
our 62hm15 had the same problem and it was the dmd fan, which means the whole light engine needs replacing. this was going to cost us $1600. I hope yours is under warranty
Posted on Aug 18, 2008
Dr Know
  • 59 Answers
SOURCE: wont charge/hold a charge
That definitely is a battery issue. The battery is either Low Soc or it is a failed battery. Most batteries on PDA's usually fail within a year because of the immense amount of use the phone has and the majority of the time the batteries are smaller in a PDA. Take your battery to a service center if one is in your area or call your carrier and inquire about the warranty on batteries (usually 1-year).
Posted on Dec 26, 2008
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
  • 259 Answers
SOURCE: no sound
it sounds like the battery is crook hope this helps regards Jim
Posted on Apr 17, 2009
I can turn my kindle on but can't get any thing else to work.
Reset Kindle Fire When it Won't Turn on or Charge
www.lovemyfire.com > Kindle Fire Problems
However, sometimes when it locks up you can't tell because the screen goes dark, either ... it's already on but is locked up and thus won't charge or work properly. ... 15 minutes to make sure it gets enough charge, and then try turning it on again. ... If this tip (or anything else on my site) helps solve your Kindle Fire problem ...
Amazon.com: Customer Discussions: My Kindle won't charge
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jan 3, 2013 - If you can't see a Contact Us button on this page, then go to .... What canI do? I sent an e-mail to Amazon but have not heard anything. My Kindle is frozen and won't ...
Mar 31, 2014
How to unlock a Kindle. Lock won ...
Jan 27, 2014
Kindle paperwhite won't turn on
Nov 6, 2013
My kindle won't turn on....green ...
Dec 12, 2011
More results from www.amazon.com
Jan 16, 2016 | Amazon Kindle Fire HD
Will not charge. Plug it in green charge light goes on, screen flashes battery low, screen shuts off green light goes out
Try resetting your Kindle. Turn off first then hold power button down for about fifteen seconds and it does a reset. This should correct the problem. Make sure you have a charger made for Kindle and not a generic one.
Jun 12, 2015 | Amazon Kindle Fire HD
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Why does my car make a loud humming noise?
The buzzing noise is air in the power steering line. The reason it is only one n one side is cause when you turn the wheel it causes more pressure to build. Take the cap off the reservoir and turn the wheel back and forth all the way hold for a second on each side until the buzzing noise goes away. If that don't work then check your rack and pinion system to make sure you don't have leakage or damage from road debris.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/nathaniel_9ed79ef078a2f164
Sep 07, 2014 | 1995 Mazda Protege
Wont turn on
Usually a reset does the trick. With the Kindle turned off, hold down the power button for 15 seconds. This will reboot the unit and should reset the settings which sometimes go out of sync like a PC does at times when the drivers don't start.
Aug 07, 2014 | Amazon Kindle Fire HD
`kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
May 15, 2012 | Amazon Kindle Fire
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
My kindle does not to turn on when i slide the power switch
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 22, 2011 | Amazon Kindle 3G
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Humming noise & color changes picture flashes from red to green
Aug 09, 2008 | Toshiba 62HM95 62" HDTV
Computers & Internet Logo
360 people viewed this question
David Payne
David Payne
