Question about T-Mobile Sidekick II
My phone won't charge
My phone will not charge...the wire works but the phone won't charge..what can I do?
  • 3172tom Dec 02, 2007
    tried botrh auto charfger and AC charger. Both gives message unable to charge battery. In addition, the battery charge level is no longer present on the display
  • kourso Dec 31, 2007
    I have had my LG 4010 for over 4 yr and now it won't indicate a full (bars) charge while I am trying to charge it. The charger red led light is on. I suspect several things, either one end or the other of the charger has some bad wiring, the phone end of the charger has bad terminals, the phone itself has bad terminal connection or the phone battery has gone bad all at once and won't show a current charging status. I don't know how to determine the cause and I don't have another charge cord or battery for this model/brand. Please advise me as to what could have gone wrong even though the charger LED light is lit ???
    I will be waiting for some assistance,
    Thanks
    kourso
    [email protected]
    _uacct = "UA-303641-1";urchinTracker();
    Habit-Forming:
  • 45 Answers
If u have a multimeter do check the output of the power supply for the voltage if it is ok then check the battery and check the supply is coming to the battery point to charge it if not the charging ic is defective do check that
Posted on Jul 03, 2007
SOURCE:
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
The phone won't turn on
Try replacing the rechargable battery inside that phone.
Jan 12, 2013 | HTC Amaze 4G Smartphone T-Mobile
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 26, 2012 | Motorola Mobility RAZR V3
My device won't charge
This situation sometimes occurs when the batteries get overcharged. Use the phone for a day and then attempt to charge. If it still won't charge, remove the battery for about a minute. Then re-install the battery and attempt to charge. If that doesn't clear the problem, you may need to get a new battery.
Mar 03, 2012 | Motorola Mobility T505 Handsfree...
Hardware
Nov 24, 2011 | Nokia 5530 XpressMusic Smartphone
It worked for a while and I was able to recharge it, but now it won't hold a charge.
Sep 01, 2011 | Cell Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
T-Mobile Sidekick II Logo
26 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
