Question about Whirlpool LCE4332P Top Load Washer
Why is the normal wash cycle light flashing on my washer
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool Duet washer, during the wash cycle, get H F error code
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
kaycee71
  • 37 Answers
SOURCE: when my washer is on normal wash cycle and half
Same problem here. Betcha' a buck it's the pump going/gone bad... Been there, done that back in 2007, so time to call the repair dude. Thank heavens for warranties! You can try all sorts of things, such as clearing the drain hose, unplugging for 3 minutes,
Posted on Oct 19, 2010
Macmarkus
  • 2605 Answers
SOURCE: Washer is stopping mid cycle (on normal wash)
Welcome to FixYa.
This is a general remedy for most Whirlpool made front-load machines, such as Whirlpool, Kenmore, Maytag, Amana etc. The "Sd" or "F2" is the same as F21 on most Whirlpool washer's and indicates the machine has detected too much soap or a obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
**This is also the reason for a no spin & the "suds" message if applicable**
Here`s how to check it and clean it...
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the Sd or "F2" or "F21" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the Sd, F2, F21 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Jan 21, 2011
  • 186 Answers
SOURCE: MY FRONT LOAD WASHER AWM8121 . IS NOT DOING A FULL
sounds to me like your timing belt is off. you may have to take it apart to look and see if you need a new one.
Posted on Jan 24, 2011
  • 6277 Answers
SOURCE: Washer will not drain in the normal wash cycle.
It is possible that there is less water to drain on 'casual' wash (?)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 07, 2011
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
The start button keeps blinking, WONT LET ME DO ANYTHING
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Maytag centennial washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
Lights flashing on Hotpoint BHWM129
I had a similar problem with my Hotpoint BHWM 129 washing machine. The washer would not spin or drain properly and all the lights flashed after a wash cycle.
The solution was to pull the washer out and UNBLOCK the drain pipe which was crushed AND filled with 'gunk'. Once the crushed pipe was massaged back to normal size and the gunk was removed my problem was fixed. Not a nice job but I was going to ring HOTPOINT at £125 a call out fee so I am happy. I hope this helps someone else in time.
Apr 30, 2012 | Hotpoint Washing Machines
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
Won't progress beyond wash cycle -- start light is flashing. Cannot switch from "normal" to delicate or any other choice. Maytag Neptune TL FAV6800AW
So I understand the issue. Does the wash cycle start up? By that I mean if you release the washer top from the base do the tumblers turn once the water fill cycle is complete?
If you don't have the FAV6800A/FAV9800A Service Manual (you can't get it on line anymore) see this post Clutch Fix I describe how to release the washer top from the base to observe the wash basket. Don't raise during the water fill cycle wait till that completes.
Does the key pad beep as you press the other cycle select key pads?
This could be a Control Board issue...........Rich
Oct 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer interupted while running
Try pressing "end of cycle". Then restart your normal wash.
If helped pl rate me................................
Jan 23, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool LCE4332P Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
