Question about Kodak EASYSHARE G610 Thermal Printer
Printing is bad
My g610 printer dock, when printing it has lines on the picture and is louder than it used to be does it need cleaned and how do i do this?
  • 32 Answers
All printers come with a utility program which allows it to run a cleaning routine. To access it you can go to the Printers & Faxes from Start Menu. From there you select the printer, right click and choose properties. Often there is a tab which offers a cleaning or maintenance choice. Run it to see if the problem disappears.
If the problem persists, you likely have need of a new printhead. These are available at stores or online.
If the unit is less than a year old or you have an extended warranty then the part will be covered. Contact your manufacturer or store on proceeding with sending it in for repair.
Posted on Jan 21, 2009
I have a kodak g610 printer dock and the paper is not being taken into the printer correctly and the printer keeps sending a message to unplug for 10 seconds and try again, any ideas
-Try to Unplug power cable for 10secs
-Remove paper try from the printer
-Make sure you are using the extralife paper or the thermal paper that came from the cartridge
-before you put the paper tray on the printer clean first all the rollers of the printer using a clean cloth
-Now if your done put it back now the paper tray
-Plug the power cable back
-Then do a test print.
If these solutions did not solve the issue please call kodak toll free 1 800 235 6325 and have it repair. GudlucK
Nov 02, 2009 | Kodak EASYSHARE G610 Thermal Printer
Computer can't find driver to communicate with printer
can you check if you have the CD that came along with the Kodak Printer? You would need that to install the printer on your computer. Once thats done, you should be able to print the pics
Hope this helps
Thanks
Ranjit
Aug 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Kodak G610 printer dock won's communicate with computer
You know I had this same problem for a while as well. The only solution I found was that I HAD to use the Kodak Easyshare software in order to print anything with it. (That was the case with my XP desktop and my Mac laptop...). But sometimes it still would not spool properly and would require unplugging the printer and plugging it back in to reset.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
No color in pictures
We had a similar problem and found out that we put in regular photo paper by mistake. You must use the paper that came with the cartridge because the printer dock uses a thermal heat to produce photos. After using that paper the photos were great.
Jan 21, 2009 | Kodak EASYSHARE G610 Thermal Printer
Printing pictures on Kodak Printer dock G610 from Kodak Easy Share on the computer
keeps giving me message "printing error" (prints ok from camera) i have probably messed up every setting by now
Oct 20, 2008 | Kodak EASYSHARE G610 Thermal Printer
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
Kodak G610 prints from docked camera, but not from the computer
it is advisable to use a recomended usb cable for your printer dock. you can try also to uninstall and reinstall the printer driver on your computer. just simply follow this steps:
Remove the drivers that your operating system automatically installed on your computer:
-- On your desktop, select Start > Settings > Control Panel > Printers & Faxes.
-- Remove all Kodak printers.
Right-click the printer icon.
Select Delete.
-- On your desktop, right-click My Computer, then select Properties.
-- Select the Hardware tab.
-- Click Device Manager.
-- In the Universal Serial Bus controllers list, right-click USB Composite Device, then select Uninstall.
note: make sure that the only device connected to your computer usb port is your G610 printer dock to make sure that the USB Composite Device that you uninstall is for your G610, most of the devices connected to you usb port has USB Composite Device also.
-- In the Imaging devices list, if any Kodak printers appear, right-click the Kodak device, then select Uninstall.
-- Disconnect the USB cable from your printer.
-- Restart the computer
-- Power Cycle the printer
-- once your computer is ready connect the G610 to your computer
-- check if you have a pop up window display on your computer informing you that your computer found a hardware device
-- you can go to printer and faxes and check if the G610 printer icon is on the list
-- try to make a test print
Verify that your computer is communicating with your printer:
-- Check that your printer is on.
-- verify if the USB cable meets your printer specifications.
-- Check that the USB cable and the power cord are securely connected to your printer and your computer.
Mar 27, 2008 | Kodak EasyShare Color Photo Printer Dock
Kodak EASYSHARE G610 Thermal Printer Logo
71 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
