Question about Huawei Activa 4G LTE Prepaid Android Phone MetroPCS
Emergency calls only message - Huawei Activa 4G LTE Prepaid Android Phone MetroPCS
I can't make phone calls or receive text messages it says emergency call only
check with your service provider as to why they are not allowing you to use the phone
what you have indicates an unpaid account and you are only allowed emergency calls
Feb 01, 2017 | Cars & Trucks
How to change emergency callls only message
Manual ways to change Emergency calls only message..
1.You mobile phone receives weak signal from near tower so try to Swich off your mobile,wait few seconds and switch on.
2.Your mobile is locked to particular network provider.
If your problem persists after switch on your mobile phone,definitely your mobile phone restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit SimpleUnlocking.com I hope it will be very useful to you.
May 26, 2014 | Pantech Ease P2020 AT&T
Say's "call emergency only " for out going calls. Won't let me call out.
This means you're either out of signal or you've been cut off by your operator. Sometimes when your phone has no signal it can link with passing satellites, and by law, they have to allow you to use their transceiver but only for Emergency Services (999). This is why you have that message. OR You have been cut off and can only use the phone in case of emergency, call your operator and find out which one it is! :)
Aug 16, 2012 | Pantech P2020 Ease Crystal Screen...
Phone not workig after emergency calls only message
"emergency calls only" means your SIM doesn't get connected to the phone or you have EEPROM code corrupted. No way to make it work on your own - get your device serviced at the local repair shop.
Jul 18, 2012 | Nokia 2730 Cell Phone
My motorola is showing, no srevice and emergency calls only. what is the sultion of this problems
hi, this is not an issue actually.
when your mobile's antennae does not recieve teh signal from the tower, you see this message. if you are just far from the signal, you'll see the emergency only, now you can call the emergency number 112 only,
when you are even not in the reach of emergency signal, it displays No Service.
you can use the Emergency signal when you are in need, you have to call 112 and an agents picks your call and helps you regarding police, fire, or you can ask them to inform some matter to others in urgency..
Narendra Tirunahari
Jul 17, 2010 | Motorola Mobility L6 Cellular Phone
Dial function says"emergency calls only"
Tried the "age old trick" of turning the phone off and then turning it back on. Wahlah!!!! Back to normal, can make calls without any problems.
Aug 23, 2008 | Samsung SGH-D900 Cellular Phone
Emergency display on right top corner of my phone nokia 6300
First try to reset factory settings of your phone. If not solved it need to be flashed.
May 09, 2008 | Nokia 6300 Cellular Phone
Message Emergency call only or searching for network....
for you..
goto setting- network setting-select gsm or atomatic-
or same problem..
try to unlock your phone..
Apr 20, 2008 | LG KG800 Cellular Phone
Huawei Activa 4G LTE Prepaid Android Phone MetroPCS Logo
91 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
