Question about Brookstone Tablet Pen Stylus Set and Leather Case
Stylus replacement tips for brookstone stylus
Need replacement tips
Brookstone massager
The old Brookstone went bankrupt. The new Brookstone has nothing to do with the old Brookstone products. Best to replace your unit.
Mar 05, 2017 | Health & Beauty
I need to replace a broken screw-in drain plug for a Brookstone foot bath/massager model # FJ1000. This was a Christmas gift and the plug broke in two
I used super glue and this repaired my drain plug. I can now used my foot spa. It's to good brookstone is not carrying a replace part when this is the most important part of the foot spa operation.. hope this helps
Jan 22, 2011 | Brookstone Health & Beauty
Need remote codes for the brookstone big remote. RCA is the tv
click the link http://mscustomercare.com scroll to the middle of the page and download instructions for jumbo remote.
Jan 03, 2011 | Brookstone 538744 Remote Control
Hi i would like to know how i can get the gray pointy part of our v smile cyper pocket pen. I have the pen attached to it but i need the pointy part. please reply
If you need to replace the gray pen insert, just go buy a nintendo DS replacement stylus and remove the same gray tip from that (carefully **** the stylus lengthwise about a 1/2" then pry out the stylus tip) and glue it in your CyberPocket pen. It's close enough.
You can also buy a replcament Vsmile controller with writing pad, and use the whole pen. (the ds stylus is, of course, cheaper!)
Sep 30, 2010 | Toys
I need to change the tip of the stylus
I own a Toshiba Tablet PC that uses a wacom stylus.
With the stylus replacement tips there is an extraction tool: It looks like a wide ring split lengthwise.
You take the tool between thumb and index ( as you do a tweezer) and extract the worn out tip.
Toshiba warns against letting the tip wear out too much: this renders extraction difficult.
Once you have extracted the worn out tip, insert a new one with the thinner side towards the outside.
Press gently but firmly to make sure it is holding.
Hope it helps.
Aug 17, 2009 | Toshiba 25 PACK DIGITAL STYLUS PEN FOR...
Brookstone Tablet Pen Stylus Set and Leather Case Logo
293 people viewed this question
Top Brookstone Electronics - Others Experts
Are you a Brookstone Electronics - Other Expert? Answer questions, earn points and help others
