Question about Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer
How do i Replace the door bellow on a kenmore 110.4508 washer
I need to replace the door bellow on a kenmore elite he4t washer
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
  • 91 Answers
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Posted on Jan 02, 2009
  • 12 Answers
SOURCE: dL F this is flashing on my Kenmore Elite HE4t
Try this site:
http://adsisecurity.com/KenmoreWasher.htm
Posted on Nov 20, 2011
  • 314 Answers
SOURCE: Replacing the Door Bellow on Kenmore Elite Front Loaders
Hi. Open up the back of the dryer after unplugging it. Take a deep breath. This is not that hard. A dryer is a very simple thing but you need to relax and figure out what the parts are. A dryer has a very basic parts list. The obvious I will not go into with but here goes with the electrical in the guts of the machine. A motor to turn the drum. A heating element. A sensor to sense high temps for safety shutoff of the element. A blower for air. Keep in mind as you look at this that usually power wires are black or red. You will see some wires that are attached to a sensor and then on to the heating elements. Take a test light or volt ohm meter and see if the high temp limit sensor is bad. This can be a simple ten dollar one from Radio Shack. That is, it will it get continuity through it. You may have to detach the wires on this sensor to do this test. The sensor is usually a flattened round disc with two leads coming out of it. Test the element same as the sensor. Take the part where there is no continuity through them to the appliance parts store with the model and serial number of the dryer for appropriate parts. Maybe ten bucks. I know it sounds scary but you may learn something and if all else fails just pickup the phone and call the repairman. Hope this helps.
good luck
please rate thes
Posted on Jan 10, 2013
What does the code DL mean on kenmore elite smart washer he4t
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
This could probably help you................... till you get a new door mechanism to replace your door lock/switch. Which is available on the net, quoting your make and model. And which you can easily fix yourself.
Jun 28, 2014 | Kenmore Elite 45986 Front Load Washer
How to replace the bellow
I have the Sears repair person here right now. $216.25 for parts and labor. I looked at other posts and I got worried about the clamp. I don't have the strongest hands.
Aug 20, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
good luck
please rate thes
Jan 10, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Iget a f-11 trouble code on my kenmore elite he4t washer.
REplace your MCU. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem. Go onto kenmore.com and find your right washing machine and replace the part yourself. First try and take the wiring harness off and then reconnect it and see if the error code goes away if it doesnt then replace the part. Please Rate. Thank you
Feb 12, 2009 | Kenmore Elite 45986 Front Load Washer
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
DOOR WONT LOCK KENMORE ELITE HE4T
Before removing try some WD40 spray on the door mechanism, not on door.
Aug 23, 2008 | Kenmore Elite 45986 Front Load Washer
Front Door Seal/Baffle Replacement
I need to replace a baffle from inside my Elite HE3T. Do you have directions? Only 1 came off but when I order the new one apparently it only comes in 3, so show I replace the other 2 as well? (if I can figure out how)
Of course the part did not come with any! And Sears customer service is of no help and the technical people have not responded to me.
Thanks,
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Torn bellows
When you get the bellows repair kit for your model, it should have the instructions and all the necessary parts for replacement.
You may need to use some muscle to replace it and may take 1 to 2 hours to complete. If you have trouble finding the part or if there are not sufficient instructions included, then email  back! ok?
Feb 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4t 3.8 Cu. Ft. King Size Capacity Plus Front Load Washer Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
