I have a Roper dryer that is only about two or three years old and when I set the timer and push the start button in, it does nothing. Why does this keep happening and how can I fix it so that it will stop doing that? Thank you so much.
Did you check where the door closes. There should be an accuatator on the door side that will depress a safety switch inside the housing. Take a flat scerw driver & push the lever in on the switch in the housing once you have set the controls to run. This could be the problem, but there could be other problems, Good luck.
hello I have a hotpoint tc7 1p tumble dryer works fine but no heat, element appears to be ok any...
(More)
hello I have a hotpoint tc7 1p tumble dryer works fine but no heat, element appears to be ok any ideas ?
my indesit is70cs condenser dryer is not collecting water in the tray but instead is pooling up...
(More)
my indesit is70cs condenser dryer is not collecting water in the tray but instead is pooling up behind the condenser unit can this be fixed or is it better to buy another?
Roper elect. drier mod #ES7745RQO drier runs , no heat. not clogged, heater switch ok, pigtail o.k....
(More)
Roper elect. drier mod #ES7745RQO drier runs , no heat. not clogged, heater switch ok, pigtail o.k. fusebox ok. can i test the coil? do i neet to take it apart?
hello.. recently the timing cam came off my commercial dryer. When I tried to reattach...
(More)
hello.. recently the timing cam came off my commercial dryer. When I tried to reattach it and align the v notches, the yellow notched piece sits below the timer wheel so it doesn't advance. the drier runs endlessly. any ideas?
