Question about Chauvet 4BAR Tri DJ Led Wash Light Kit Stage Bar System ADJ Flash Sh
Flashing 4bar tri - Chauvet 4BAR Tri DJ Led Wash Light Kit Stage Bar System ADJ Flash Sh
I have a faema x1 grandaitalia machine , the water coming out of the boiler is only getting to 33 deg can you send me or a diagram of hot water system thanks or tell me what to fix problem
Ope you mean from hot water spout if so several problems exsist as this machine has a cold mix system to bring the roughly 120c water from boiler down to roughly 94c to use for americano. check spout and descale hot water nozzle or see if any black/brown particals in defuser(fine mesh in spout)as boiler pressure is roughly 1.3/1.4bar and mains water is roughly 2/4bar thus cold water will win if black brown particals in mesh poosible boiler contamination causing restriction to which once again cold water will win. question did any one take any pipes apart about 5 months ago????? as there are restrictors within the system.
Aug 15, 2012 | Faema Coffee Makers & Espresso Machines
At idle the oil pressure light comes on
i would say the car is safe to drive.IF the pressure sensor was working correctly, and your engine was a complete dog, then you would expect there to be some loss of oil pressure, but not 0 to 4bar in a blip of the throttle.given that the oil pressure sensor is a common fault (and it controlls the oil pressure light, it is not a seperate switch), i would say the sensor has a 'dead' spot on it, and a blip of the throttle just sees it outside the dead zone of its reading, and pings back to 4bar (its natural to get a slight rise in oil pressure when higher revs are acheived). 4bar is the right value, its what mine sits at. maybe a tiny bit under (3.95) when the engine is very hot/in traffic the oil pressure is reading just over 4 at all times, dosent go up or when accelerate or down at idle is this normal, used to mercedes W124 where it can register .3 up on idle but when accelerate it should goto max, ie 3 bar Whats the mileage on the car. Sounds like It certainly is suffering from low oil pressure at tickover, but loads of cars do and continue running for thousands of miles. blue/white smoke on start up and that points to valve seals and, yes, the head would have to come off to replace them, but it's normally just blue smoke. White smoke points more to head gasket, but that would be replaced anyway when doing the valves.Bet the engine sounds smooth as silk too
Oil pressure is determined by the rate at which oil flows through the internal combustion engine of a car. Low oil pressure is a real danger for engines, as it indicates that the bearings in an engine have worn, allowing the oil to flow more easily and at a lower pressure. However, high oil pressure is generally not a concern for motorists. Oil pressure fluctuates with the heat of a machine, and though high oil pressure can indicate a serious problem, it generally means the engine is in an adjustment period.Oil Pressure at Idle For many cars, oil pressure is much higher upon start-up or while idling. The reason for this has to do with the temperature of the engine. When an engine has been sitting turned off, it cools down, as does the oil that flows through the machine. Upon start-up, the engine temperature begins to rise. As it rises, so to must the oil heat up to find a level pressure to flow through the machine. Cooled oil is thicker, causing it to flow more slowly and at a higher pressure through the machine, until it reaches its optimal operating temperature.Pressure Relief Valve Recurrent high oil pressure, even after the machine has been running for a while, can indicate a problem with the pressure relief valve. The pressure relief valve is responsible for regulating oil pressure throughout the internal combustion engine. It is a safety device intended to keep vessels or piping from experiencing extreme pressure. When this device is malfunctioning, it will cause high oil pressure in an automobile.Types of Oil The type of oil put into an engine can also account for extremes in oil pressure. Low-weight or thin oils will operate with low oil pressure, as they will pass through the machine quite easily. Thicker oil will pass through the machine at higher oil pressure readings. Generally, after an oil change, when fresh oil is introduced into the machine, oil pressure will increase. This, however, is only a sign that the oil that formerly operated your car was too thin for optimal performance.
Oct 19, 2011 | 1995 Jaguar XJ6
I have just bought two of these units for my son's band and cannot get them to work in master slave mode with one footswitch. Any help would be appreciated. Please remember I am a total novice so an idiots...
DO NOT RUN THEM in parallel or the power will explode internal circuits.
Have you cleaned the imputs and outputs?
Does it show a power light?
Answer these Qs with As and I will help you
Feb 25, 2011 | Chauvet 4bar 4 Bar Wash Dj Led Lighting...
New battery, new alternator, new starter, still won't start, 1994 chevy cheyenne 5.57 v8 ck2500
Get a fuel pressure gauge and measure on the fuel supply line on the rear of the inlet manifold. In my experience you need close to 4Bar while cranking. Priming pressure should be about 4.4Bar. This test will eliminate a variety of possible problems. I need more history to be more specific.
Oct 09, 2010 | 1994 Chevrolet K2500
I have this Electro GSN one. When I mounted a normal flash, the flash doesn't function. What is the solution? Does it need a special flash which differently? Thanks for your helps. Reap
You can use any flash that has one contact at the shoe.
Try using the PC flash cord to the flash socket on the camera body and see if the flash fires. If you see flash with pc flash cord and not with the accessory shoe, try cleaning the flash contacts at the hot shoe.
If no flash either using the hot shoe or the flash cord, try testing the flash. If the flash is good, you have to open up the camera to trouble shoot. The flash wire is connected to the shutter's flash contacts.
Jun 01, 2010 | Photography
2000 chevy ck 2500 5.7L 4x4
Get a fuel pressure gauge and measure on the fuel supply line on the rear of the inlet manifold. In my experience you need close to 4Bar while cranking. Priming pressure should be about 4.4Bar. This test will eliminate a variety of possible problems. I have had a variety of problems and found this very helpful.
May 14, 2010 | 1997 Chevrolet C/K 2500
Vaccum lines on f150 5.8 engine have been torn off and need diagram and definitions of abreviations on diagrams. 1985 mod holley 4bar carb
I assume the under hood label is missing. Try auto zone's web site at http://www.autozone.com/autozone/ they may have a diagram. Other than that my suggestion if you cannot find a diagram would be to find a truck exactly the same year with the same engine and take a digital photo of the diagram under the hood if there is one there. Otherwise ask the owner if you can copy the connections. The vacuum hose connections are very specific to your make, model, year, and engine size. I looked and could not find a diagram. Sorry I can offer no more.
Apr 07, 2010 | 1985 Ford F150
Wo kya cheez hai? jo saal me 1 bar, Mahine me 2 bar, Hapte me 4 bar aur din me 6 bar aati hai?
"woh kya cheez hai jo saal me 1bar,mahine me 4bar, hafte me 6bar aur din me 2bar aati hai
Mar 19, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Chauvet 4BAR Tri DJ Led Wash Light Kit Stage Bar System ADJ Flash Sh Logo
Top Chauvet Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Chauvet Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
