Question about Garden
Can I use sae 20W-50 oil in my briggs and stratton 375 sprint mower
  • George Rhodes Jan 12, 2013
    Very helpful - cheers.
  • 2,239 Answers
No, it should take a straight sae 30 grade oil.
Posted on Jan 11, 2013
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 4 Answers
SOURCE: The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
Posted on May 05, 2009
rycgl
  • 1545 Answers
SOURCE: I have a Sovereign sv46d
Since you have a Briggs...and you have the OEM part number...go here:
http://www.ereplacementparts.com/
Posted on Aug 12, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a lawn mower
Hi eugenemcmena...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 07, 2011
dwebster766
  • 3 Answers
SOURCE: How do I change the oil on a Briggs and Stratton
take it to a lawmmower shop
Posted on Aug 25, 2012
What oil do I use for a briggs and stratton 650 series
Any good grade of SAE 30 will do fine unless on cold weather operation..then SAE 10-30 ..
May 22, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
Toro 20450 Recycler Mower with a B&S Model 12V engine...how many ounces of oil does it require
Most all of the smaller Briggs and Stratton mower engines require 20 ounces of oil. Use SAE 30 and I suggest using the Briggs Brand or synthetic. If you use synthetic, you can get away with using a multi-viscosity oil like 10-30W. But if using plain old automotive conventional oil, definitely SAE 30W only.
May 06, 2011 | Toro Power Lawn Mower
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Can you please advise which oil to put in my B & S rideon mower. Model 261777 Type 013801
Hi verndono,
Briggs and Stratton recommends to use SF or SG. SAE-30 or 10w-30 oil for temps above 40F (4C) , SAE 10W oil for temps between 40F (4C) and 0F (-18C) and SAE 5W-20 (or 10W oil diluted with 10% kerosene) for below 0F (-18C). I suggest you use 10W-30 or SAE-30 and you will be good to go. Hope this helps. Best regards. Denis.
Mar 01, 2011 | Briggs & Stratton Garden
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
537 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
