Question about Toshiba Satellite Computers & Internet
Beeping on start up
On start up the laptop has a continuous beep for about 20-30 seconds, during this the screen is black and then slowly boots to home screen
    Problem Solver:
  • 17 Answers
How old is laptop?... this indicates a failing HDD... back up all data and documents immediately and run repair disk in windows as chkdsk on boot cycle
Posted on Jan 10, 2013
SOURCE: Beeps at Boot Up, but doesn't actually Boot Up.
u can try to take off the hdd, and at the same time, pls clean the memory slot in your laptop with a brush & some liquid solvent.. After that, try booting it without any HDD. If u did not see any error messages, try take out the CMOS backup battery and neasure its voltage or get it replaced. Pls revert...
Posted on Oct 09, 2007
Eddie333
  • 176 Answers
SOURCE: Latitude D600 beeps twice
Sounds like you have a video card problem.
To run the Dell diagnostics perform the following steps:
  1. Shutdown the computer.
  2. Press and hold the <Fn> key (next to the <Ctrl> key), then press and release the power button.
    Release the <Fn> key when:
    • The keyboard lock symbol lights begin to flash AND/OR
    • In the upper left corner of the screen shows Diagnostic boot selected
  3. The diagnostics testing automatically begins.
    It may take a few minutes before any alert tones are heard.
  4. Watch the screen for images such as the Dell logo, progress bars,or lines of text and/or listen for beep tones that sound similar toMorse code.
  5. If the screen does show an image, write down the codes that appearon the screen. If the screen does not show an image, write down thebeep tones that you are hearing.
    • Before going further, please click the link to listen to an example of a beep code. Sample Beep Code
    • The beep codes will begin with a quick series of high pitched beep tones, then a pause, then 3 sets of beep codes.
      Write down the 3 sets of beep codes that you hear.
    • If an error code is recieved, scroll back to the top to "Choose an option"and choose "A beep code is heard or an error code is seen. The beep code is not 3-3-3 or 3-3-4."
    • If there is no error code, continue with step 7.
  6. After approximately 2 minutes the system produces a single alert tone and should display colored bars with the prompt Were color bars displayed? (y/n).
    The alert tone is repeated 6 times, once every five seconds for 30 seconds, then the second test automatically begins.
    Press the <N> key on the keyboard to skip the timeout and immediately start the second test.
Posted on Jan 04, 2009
  • 87 Answers
SOURCE: Beep noise during booting and no keyboard response
Sounds like the key is stuck. You will have to remove the keypad to check the switch underneath.
Posted on Mar 14, 2009
  • 3 Answers
SOURCE: a beep sound is coming from my laptop during booting
That's a really annoying sound! I made it mute using this trick:
http://www.myhowtoos.com/en/windows-howtoos/78-how-to-remove-a-beep-sound-on-the-laptop
Posted on Jul 13, 2009
parrotheadpc
  • 2600 Answers
SOURCE: windowos doesnt boot, continuous beeping
Try this....
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 08, 2009
Black screen boot but doesnt continue
You could attach an external monitor to see if any thing is going on in your PC.
Remove the RAM memory chips out and observe if you can hear some beeps.
Apr 21, 2012 | Computers & Internet
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
Hearing continuous beep sound at startup that disappears on Esc
I started having the smae problem yesterday with my Acer 1410 bought end of 2009. It started after I had stoped some suspicious process to work on start up (using msconfig). During the night I scanned the computer for virus but found nothing. Tonight I will enable those process to work on start up again and see what happens.
I will post the information tomorrow.
Aug 02, 2010 | Acer Aspire One PC Notebook
Long beep during starting-up the computer
during this long beep, what happens next, is there any display on the screen? is it a desktop or laptop? if it is desktop: and the long beep is it continues? one ur memory could be bad. or ur display card. remove and replays with another working once.
Jun 16, 2009 | Microsoft Windows XP Home Edition
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
Beeping before booting
probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Nov 19, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
A beep sound is coming from my laptop during booting
what is the beep combination? how many short and how many fast beeps?
Apr 22, 2008 | Computers & Internet
Packard Bell error signals
here is a list of packard bell beep codes with meanings
http://www.uktsupport.co.uk/pb/mb/phnxcode.htm
Hope it helps you
Nov 13, 2007 | Packard Bell Easy One Silver 2101 Notebook
Computers & Internet Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
