Question about Frigidaire FEQ332E Electric Dryer
My dryer -model FER311F makes a thumping noise while in use.
Dryer making thumping noise while tumbling in full revolution.
  • 1 more comment
  • sherri_somme Jan 21, 2009
    The dryer is level. It is inside the dryer -may be a bearing or the drum wheel?
  • tmcnally1 Feb 03, 2009
    it sounds like the drum is sticking
  • johoodrat Feb 06, 2009
    my dryer only used to make a thumping noise sometimes but now the noise is becoming more and more frequent. i pulled the dryer away from the wall and made sure it was level. eventually i guess i will have to take my dryer apart.
    Problem Solver:
  • 3 Answers
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Posted on Jan 21, 2009
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Thumping noise when drum makes a full revolution
Open the cabinet and look at the screws that hold the vane (paddles) on inside the drum. They will come loose and make the noise you described.
Dec 26, 2010 | Frigidaire FER641FS Electric Dryer
I have an electric frontload dryer. If I turn it on with nothing in it, it sounds like there is a shoe tumbling around. If I open the door and spin the drum by hand, each revolution the drum makes, there...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 22, 2010 | GE Dryers
SOUNDS LIKE YOU ARE DRYING SHOES IN THE DRYER. EVEN WHEN THE DRYER IS EMPTY!
Bad rollers
These rollers get a flat spot on them and make a thump type noise with every revolution. More HERE
Jun 10, 2010 | Kenmore Rear Control 8885 Dryer
Maks thumping noice
Replace the rear drum roller supports.
Jul 08, 2009 | Whirlpool Dryers
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
My new dryer thumps every revolution
Flat spots on the support rollers from sitting in storage will make a thump. So will heavy wet clothes if they are not spun dry enough from the washer. This may lessen as the unit is used but since it is in warranty a service call to rule out major problems is in order.
Eric
Jun 17, 2009 | Maytag MDE9206 Dryer
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Apr 04, 2008 | LG DLE2514 Electric Dryer
Frigidaire FEQ332E Electric Dryer Logo
390 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
