Question about PfaFF Sewing Machines
Broken part I am trying to find a thread guide for lower looper threads
  • 11,896 Answers
Here are your guides: (copy and paste in your browser)
http://www.ehow.com/video_4437044_thread-lower-looper-serger-sewing.html
or/and
www.riccar.com/ftp/whitepapers/564DE_LGSG.pdf
Posted on Jan 21, 2009
Elna Pro 4De serger thread breaking
Be sure to thread each in the ORDER specified--for most machines (but yours may differ) upper looper, lower looper, then needles. Follow (closely) the threading diagram on the machine. Missing one guide or hitting the guides out of order will throw you machine into a tizzy! On my serger, the lower looper has to lay over the top of the upper looper/thread before it all gets pulled under the presser foot toward the back of the machine.
It also may help to RAISE the presser foot when threading the machine.
Having problems threading my Elna Pro DE 4 sewing discussion topic...
Threading elna lock pro 4 DE green knob
Oct 06, 2017 | Elna Sewing Machines
On the lower loop blue keeps breaking
Looper thread breakage occurs frequently when the thread path is incorrect or threaded out of order. Most machine must thread the upper looper first, then the lower looper. The lower looper thread ends "draped over" the upper looper in the last step before being pulled toward the back of the machine and under the presser foot.
Another common cause is tension that is too tight.
VERIFY the thread path is correct for every thread!!!! Missing a thread guide or looping around a guide will throw your machine for a "loop."
Another hint, when threading, ALWAYS RAISE the presser foot throughout the process and be sure to give each thread an "extra little tug" when going through the tension to make sure it is seated completely. Sometimes, the thread will even "pop" when it seats. When a thread break, checks that the thread has not "jumped" out of a thread guide or the tension disk.
If the thread breaks, it is usually less frustrating (in the long run) if you remove ALL the thread and start over from the beginning. Trying to snake a broken thread out of order through the sequence is frequently 99% UNsuccessful!!! It takes a lot of familiarity with your machine to be successful threading out of order, but there is still a lot of room for failure!!!
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH
Make It Handmade How to Thread Your Serger Out of Order
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
Nov 17, 2016 | Sewing Machines
Overlocker is not sewing. How can I thread the lower looper without it breaking?
Thread breakage is usually an indication that the machine is not threaded correctly or the tension is set too tight.
As a reminder, if a thread breaks, save yourself some (lots!) frustration and rethread every thread From The Beginning. Rethreading only the broken thread will usually just lead to it breaking again. Sergers are finicky and must be threaded in the correct order. Also, Always raise the presser foot while threading. Your thread breakage is occurring with the lower looper. Be sure that you are threading every guide and give it a little tug going through the tension disk. Usually, the last step is to drape the lower looper thread over the top of the upper looper before it is pulled back and under the presser foot. Be sure to initially set the tension at the midway point between the high & low numbers.
My serger is still not working properly trhread still breaking lower and...
Apr 07, 2016 | Sewing Machines
L5 serger overlocker. Why don't the threads make a chain?
rethread machine, make sure u thread all steps
Jul 14, 2015 | Elna Sewing Machines
I need to replace lower looper field assembly as the clip at the end is broken. I'm struggling to source the part, i think the part no is x7777-001 but it seems to be discontinued. i bought the machine...
I have the same problem with my brother 1034d the small bolt in the thread guide has come off and I can't thread lower looped with out the thread breaking, I have looked everywhere and cannot find a replacement part, have you had any success ?
Oct 05, 2013 | Brother 1034D Mechanical Sewing Machine
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
Bernina 800d sewing machine
You might take a look on ebay item with bernina 700d/800dl instruction manual
Apr 28, 2010 | Bernina 1008
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Brother serger thread
The lower looper thread MUST be threaded before the needles are threaded. You must also be sure the lower looper thread is pushed and staying all the way to the left before it is threaded through the looper eye. Double check the threading diagram and count the number of guides the thread passes through. Count how many guides you have actually passed it through. It must be the same. The dealer you bought it from should be willing to show you if you can't figure it out.
sewman7
Jun 17, 2008 | Brother Lay-In Thread Serger Mechanical...
Lower loop broke- do I have to start from step one?
yes, take all threads out, and re=thread according to the diagram, following the threading order.
Mar 02, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
107 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
