Question about Miller matic 140 Mig Welding Package W/As 907335
Ignighter wire the ignighter wire keeps burning out the fuse
You need heavier service wire and a higher amp fuse
hiharold2003
Posted on Jan 21, 2009
My wiper fuse keeps burning out
If your wiper fuse keeps burning out, your wiper motor might be failing which causes too much amperes required to turn the motor which in turn trips the maximum rated amperes of the fuse.
Follow the wiring of that fuse to your wiper motor to make sure the wiring is not nicked and grounding to the metal. Once you confirm that there is no shorted wire, disconnect the wiper motors wiring connector. Fuse a new fuse and if the fuse does not blow anymore then you isolated the problem which is the wiper motor causing the fuse to blow. Fix or replace the wiper motor.
When diagnosing blown fuses, I usually temporarily replace any fuse in a vehicle with a circuit breaker type fuse. If there is still a short somewhere in the wiring or the component itself in line with the fuse, the circuit breaker fuse will just trip and I just reset it again after I fix the problem. An advantage of keeping to replace a blown fuse while diagnosing.
Oct 04, 2015 | Cars & Trucks
Power window fuse burns out on mercedes 1987 190d
Get yourself a wiring diagram & test the system
to find a problem,failed component or wiring causing
the fuse to blow
Sep 07, 2014 | Cars & Trucks
Why does my fuse keep blowing
If its the correct size fuse you have a short causing the fuse to blow. if its a fuse to say the a/c compressor, the compressor is pulling over the fuse size and causing it to blow.
Aug 17, 2012 | 2002 Saturn L-Series
Keep breaking fuses on T/L Ctsy after my son hooked a power wire there for his amp. now it keeps breaking fuses.whut can i do to fix this.
it sounds like the power wire you Son hooked up is not grounded and keeps blowing fuses. Try grounding that wire and make sure its not touching any others to spark and burn out fuses.
Oct 14, 2011 | 1991 Chevrolet Suburban
Fuse #109 keep blowing/ driver seat not working please help
If the fuse keeps blowing, I assume it is because you keep replacing it. Those fuses have given up their lives to keep your truck from burning to the ground. Each time a fuse blows, the wires in the system get heated up and weakened. If you keep replacing the fuse, the insulation will eventually burn off of the wires and light the entire truck up. There is a shorted component or wire on one of the circuits that are protected by that fuse. Replacing the fuse without locating and repairing the reason that it blew, will only result in another fuse having to give up its life to keep your truck from roasting and all the other fuses will have died in vain.
The circuits to that fuse will need to be traced, using the wiring diagrams for your vehicle and the proper equipment necessary for performing tests on your electrical system. Nobody online can tell you what the actual cause of the problem is (other than tell you there is a short) without performing the necessary tests on the vehicle itself.
Jan 29, 2011 | 2006 Ford F-150
My dryer does not heat up . I alredy replaced the ignighter
Take a look and see if the glow coil comes on. If not, take the back off the dryer, and you will see a part about an inch and a half long, by a half inch wide, and it is white in color. That is the thermal fuse. Make sure the dryer is unplugged, and take the 2 wires off the thermal fuse, and put the terminal ends together, and put a little tape on it, so it does not hit metal, and then see if it works. If it does, DO NOT RUN the dryer that way. That thermal fuse is the only thing stopping that dryer from burning down the house. If it does not work it will be the flame sensor.
Oct 19, 2010 | Whirlpool Dryers
1995 Goe Prizm dome light and gigarette lighter dosen't work, but fuse is good.
Make sure its grounded good and the plug is in the back of the ignighter..also wiggle wires behind fuse box ..
Sep 05, 2010 | 1992 Geo Prizm
Acura 96 rl wont start. Checked all fuses ender the hood and in the fuse panel. Pulled starter relay and checked connectivity also ignition switch plug. All points checked out. Cant find neutral switch and...
since youve said that al other checks were good then im lead to believe that the ignighter is bad usually you can find this under the dist.cap you will have to take the cap off remove the coil and this will give you access to the ignighter pull it up and out disconnect the wire harness and replace with a new one.
Jul 05, 2010 | 1996 Acura RL
Car wont start
test light on neg with key on power at both sides of coil ???? next test light on bat plus put to coil neg and have somone turn car over if test light flashes and still no spark coil is bad if test light no flash ignighter is most likely bad the ignighter switches ground on your coil for spark
Dec 23, 2008 | 1994 Toyota Camry
Gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
Jun 21, 2008 | Stoves Premier 720GRa Gas Double Oven
Miller matic 140 Mig Welding Package W/As 907335 Logo
62 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
