Question about Microsoft Xbox 360 Elite Console
My xbox died
My xbox made my screen all fuzzy and then it died. What should i do
  • ryanlee874 Feb 04, 2009
    i have the same problem im going to send my elite to microsoft to let them repair it i worked it was at the back where the av cable inserts
    Sergeant:
    Champion:
  • 378 Answers
If its not covered under warranty we can fix it for you. You can check out our site
www.videogamerepairservice.com
We are registered on this site also.
Thanks
Posted on Jan 21, 2009
How do I fix a fuzzy screen
A fuzzy television screen is generally not the fault of the game console itself, but of your television.
The Xbox 360 is an HD game console, and from personal experience, trying to render an hd image in 480i Standard Definition will cause it to look somewhat fuzzy regardless of the television.
Just to make sure it is not the Xbox, I would, if possible, suggest you try the 360 on another television, preferrably with the HD cables (remember that there's a switch on the cable itself that you will need to switch from SD to HD).
Unfortunately, if you do not have access to a high def television, you can always fiddle with the contrast and sharpness on your standard def TV to reduce the fuzzyness, but the screen will always be somewhat fuzzy.
I realize this is probably not the answer you wanted, but to solve this problem for my own Xbox, I ended up purchasing an inexpensive HD Television.
Nov 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 dreaded Pink Screen...is it getting ready to die? TV is fine, movies are fine its just when games are being played. The screen is not solid pink, but the detailed aspects of the game are fuzzy...
I am afraid it might be going, I would try disconnecting the video cable and leaving it off for about a day. If that doesn't work, I would contact Xbox support, see what they say, and go from there.
Nov 06, 2009 | Microsoft Xbox 360 Console
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
When turning on the xbox the screen turns pink
OK did you ever try to hack your system did you open the inside of it did you drop or smash it or leave it in extreme temps if not it might be the result of poor cable connection,first turn off your Xbox 360 and check out the cables that are connected to the system. Remove them and re-connect them firmly. Now switch on your Xbox 360 again. There is a good possibility that you will find the fuzzy purple screen gone. If you still find a fuzzy purple screen then this might be a bit more complicated problem that your system is experiencing. Usually system overheating is one of the major reasons that cause various Xbox 360 errors
May 05, 2009 | Microsoft Xbox 360 Console
Xbox 360 Blurry/Fuzzy Screen
This means its most likely over heating and the GPU is on its way out...
you can try using a diffrent cable see if this helps.
if not contact microsoft as they now have 3 years warrenty on them :)
thanks
alex
Apr 06, 2009 | Microsoft Xbox 360 Console
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
There are fuzzy lines on the screen when i play any of my games
you could try checking the AV cords that connect your TV to you xbox 360 and making sure they are securely connected
Jan 28, 2009 | Microsoft Xbox 360 Console
Screen failure
sounds like ur xbox is about to go red light soon. It is fixable and i can list the steps for fixing it if u'd like. Kinda complicated, but ive fixed 30+ systems using the process
Jan 13, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
