Question about Thermador PRG484GGUS Gas Kitchen Range
How to remove drip pan of thermador range - Thermador PRG484GGUS Gas Kitchen Range
Thermador grande 36 range with grill
gas flame cheak burners and air passing throw them make sure clean cheak gas going in valves to see what its pushing might wann push more have tech come out do this fo u thx nick
Feb 10, 2008 | Thermador PRG304US Gas Kitchen Range
I have a GE range for which the former home owner did not leave a owner's manual. I need to know if I can put the drip pans in the oven while the stove is being cleaned. When I looked for that info, I...
If your drip pans are chrome plated NO you can not put them in the oven during the self clean cycle since the chrome plating will be burned off PLEASE BE ADVISED the racks also need to be removed during the self clean since the chrome will burn off of them as well...if your drip pans are porcelean coated they could go in durning self clean.
GENE
Sep 08, 2011 | Kitchen Ranges
Can you cook hamburgers and pork chops on the griddle hot plate?..if so, should there be a drip pan beneath the holes in the griddle to catch the grease?
There should be a drip pan already but remove the griddle and line it with aluminum foil that way you can just roll up the foil and throw away and you don't have to clean the drip pan. If you cook pork you need to cover with a lid and you want to make sure you get the meat hot enough to be safe, get a thermometer from Wal Mart and it will have a probe and the temp the meat has to be in order to be safe. Chicken is 160 beef is 140 and I don't eat pork and don’t know the exact temp for it but the problem will have it on it. If this helped please rate me.
Aug 07, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Back burner caught fire
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Jun 17, 2009 | Kitchen Ranges
Drip pans no longer available in black, just in grey
Yes you can spray paint them black. Just be sure to get high temperature black paint, like what you might use for a gas grill. Home Depot, Lowes, most any hardware store will have it in stock.
Apr 30, 2009 | Kitchen Ranges
Drip pan
You can buy this pan at your local appliance parts store. All you need is your model and serial number.I hope this helps you.
Nov 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric coils for old Thermador cooktop Model #TMH45
I have a thermador 45 cooktop with all the parts. Do you want to by the whole unit for $50.00.
Jul 20, 2008 | Cooktops
Drip pan
I don't have a solution, but I am trying to figure out how to remove the sealed burner drip pans on a Thermador PRSG 364 GLS gas stove. Any suggestions?
Apr 29, 2008 | Thermador RDFS30 Dual Fuel (Electric and...
LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Dec 10, 2007 | Thermador PGR366 Gas Kitchen Range
Thermador PRG484GGUS Gas Kitchen Range Logo
55 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
