Question about Sony Ericsson S710a
S710a problems I cannot turn on the phone. I charged it all day, then hit the power button and all I get is a black screen that says Sony Ericsson. Sometimes, when I turn it on I get an all white screen and that is it. If I take out the sim card it usually boots up to the main screen just fine, but says insert sim. When I put the sim card back in I have the same problem. My phone was not water damaged or dropped. I just woke up one morning and had these problems. Thanks for any help.
  • optics Nov 17, 2007
    Same problem for me, just one day kept freezing, I'd reset it, work, freez after some time. now it just freezes. i bought a new battery, didn't seem to help. Same deal, remove the sim and goes right to the screen very fast, then put it back in and slow, and freezing.
    I emailed SE, they said to master reset.. which obviously they didnt listen as I can't get it on all the way to do so, then they offered to look at it for $185... I passed.
Buy a battery on ebay, its really cheap, I just found one under $6
Posted on Jan 27, 2008
I am having the same problem - it won't hold a charge. Red light shows it is charging, but nothing. It may be the battery. I just called S.E. and they said it may be the battery. I ended up getting a new phone since batteries cost almost as much as a new phone.
Posted on Jul 07, 2007
Unlock phone
Use unlock to unlock your mobile...Get the unlock code here http://www.mobileunlocksolutions.com/unlock-your-phone/rs1wp2/ and also get the unlock in the same site....
Aug 24, 2008 | Sony Ericsson S710a
No power s710a
First off, is it showing any source of power? If no lights are turning on, check to make sure the battery has a good connection to the pins. Most likely it is a pinched wire inside the case. You will have to reopen the case and move the wires around to make sure they are no longer pinched. Unfortunately, you may have damaged circuitry. If you attempted to power on the phone before rice drying it, then most likely you did, and thats why it will not power on. I suggest rice drying it, after about two days, place the device on a charger. If the red light does not come on after a few hours of charging, the phone is dead, sorry.
Apr 30, 2008 | Sony Ericsson S710a
Won't turn on S710a
Your problem is this phone is equiped with a 23-44 pressure sensor, let it set for 4 or 5 days to reset. thats what i did, oh take out the batt.
Apr 12, 2008 | Sony Ericsson S710a
Unlocking S710a gsm phone
You need the USB Dock, not the DCU cable, the cable won't work with what you need, Then go to the support section of Sony Ericsson and upgrade the phone (new firmware) that should unlock it. .
Dec 22, 2007 | Sony Ericsson S710a
How to retrieve battery
Turn the phone over so that you read Sony Ericsson properly on the back cover. Place your thumb on it and slide left. Now press on the bottom corner of the battery nearest the camera. This should cause the battery to tilt up and you can easily pull it out, otherwise there is something wrong with your phone.
Dec 16, 2007 | Sony Ericsson S710a
S710A I ONLY USE SPEAKER PHONE
This is because the speakerphone and the earphone are 2 different speakers. Which means your earphone is blown, or something is wrong in your settings, check your different volumes.
Dec 07, 2007 | Sony Ericsson S710a
Screen broken
Did you attempt a hard shut down, meaning you hold the power button down till it turns off. To me it sounds like you damaged the LCD internally, I would suggest turning it off, charging it overnight, and then attempting to turn it on. It could be several problems I know mine did that when I water damaged it but I riced it and its fine now.
Nov 10, 2007 | Sony Ericsson S710a
I bought a sony cell phone s710a
Take it to Cingular, or call gophone, it probably needs settings sent to the phone.
Aug 26, 2007 | Sony Ericsson S710a
Sony Ericsson S710a Logo
98 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
