Question about Sony KV-35S45 35" TV
Do I need an antenna on my sony model # KV35S45 TV when I cancel my cable?? If so, where is the antenna connection on the TV?? I can't find one. Thanks.
    Genius:
  • 1,199 Answers
YES! the antenna will plug into the same spot the cable wire is connected too ( you may have to buy a adapter for $1.00 for the the antenna wires to connect to back of your set available at any wall-mart or radio shack) And since your switching to antenna you will need to buy a digatil converter box in FEB to get antenna TV!
Please rate this response and help us keep this area free!
Thank You!
Posted on Jan 21, 2009
How to connect HDTV antenna to an old Sony Am Fm Radio Tv Receiver, Model Tv-413?
yes there is an coax to ant adapter. Check walmart or Radio Shack if they are still in business.
Apr 06, 2015 | Sony Am Fm Radio Tv Receiver, Model...
I have a Sony rear projection tv model # KP 53HS10 I need to connect to a Direct TV satellite box
Depending on the way that you want to do this, you can use a short coax to connect to the antenna input and the sat box. You can use component cables to connect from the sat to the set. If you do that you need 3 cables for video and two for sound. You can use svideo also and maybe digital audio.
Dec 27, 2014 | Sony Televison & Video
No signal stuck on channel 2 with black screen. Model KDL37M3000
Are you connected to a cable or sat box, Are you connected thru antenna input on tv or a/v input. If connect to box thru antenna jack of tv do channel search to pick up ch 3 if box is set to that. If connected to outside antenna still do channel searsh but be sure tv is set to antenna. If connected via av or hdmi the cable or sat box is bad.
Apr 01, 2014 | Sony BRAVIA Televison & Video
Can I install an external antenna to this TV?
it is located next to the power plug and if you have more than one tv in the house you will need to use a splitter
Oct 16, 2013 | Sony KLV-S23A10 23 in. LCD HDTV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Nov 03, 2009 | Vizio L37 Television
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Watching Cable TV
this Sony is a MONITOR not a TV. You need a cable box or a satellite tuner/receiver. There is no built in TV Tuner in this model
Jan 17, 2007 | Sony PFM-42X1N 42 in. HD-Ready Plasma...
Sony KV-35S45 35" TV Logo
113 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
