Question about iRobot Roomba 4210 Bagless Robotic Vacuum
My Roomba does not want to dock
Roomba won't dock
  • Anonymous Jan 23, 2009
    I have put my Roomba on a schedule.  It will clean, but it won't dock>
  • Anonymous Feb 12, 2009
    Ever since I set up my scheduler, my roomba no longer docs
    Problem Solver:
  • 15 Answers
Need more info.
Does the unit go into search mode? "SPOT & CLEAN" flashing? It actually tries to search?
Do you have another roomba to test your dock on to see if IT will dock? If it tries but just cant, then either the dock transmitter, or the roombas receiver is dead. (The round antennae thingys on the dock and the bumper) replace these would be the first point.
Posted on Jul 24, 2010
3 Suggested Answers
bobfiala
  • 28 Answers
SOURCE: Roomba Docking Station
Probably not, unless you just have to have the docking station. My roomba always had trouble mating with my docking station so I never used it. I just plugged it directly in to will using the AC adapter.
Posted on Nov 14, 2008
  • 8 Answers
SOURCE: My Roomba 560 does not automatically dock as advertised either..
You may not believe this, but the new 500 series lighthouse virtual walls have both infrared and radio frequency communication. How they work and associate with the Roomba is pretty complicated. The best posting I've ever seen about how they work is here:
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=11048
Check out that link to understand how the communication works.
If your Roomba is contained by the virtual walls, then you can assume the IR sensor on your Roomba us good....you should test that though. Then you might have to replace the "home base" which could have a bad IR transponder . New ones can be found for reasonable price at www.RoboticVacParts.com or you could order straight from iRobot for twice the price.
If the Roomba is not contained by the virtual walls, then the IR sensor on the Roomba is likely bad and you'll need to change the bumper on your Roomba. Again ....parts are available through ebay, or www.RoboticVacParts.com. Follow this link if you need it.
http://cgi.ebay.com/NEW-Roomba-500-series-white-bumper-510-530-532_W0QQitemZ270400281066QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef51cd9ea&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Posted on Jun 20, 2009
17062 won't work
Check to make sure your docking plugs are not plugged up with dirt or dog hair. That can prevent your Roomba from charging.
Nov 28, 2017 | Roomba Vacuums
My roomba will not charge on the dock. I have had it for 1 year. The dock is receiving power as the green light is flashing. What can we do?
Try using some fine sand paper to clean the pair of metal contacts on both the vacuum and on the dock (unplug it first). They may be dirty and not making adequate contact.
Dec 29, 2016 | Roomba Vacuums
Roomba Schleduler Charging
Bad battery most likely. Could be a faulty charger too. Have your local vac shop test it.
Jun 07, 2017 | Roomba Vacuums
I roomba wont dock
That's usually caused by a charging issue. Could be that the contacts the roomba uses to charge on the base are bad or the contacts on the roomba its self. Here is a good troubleshooting guide. Roomba customer service is very good too, if the roomba is less than a year old they will repair it for you. good luck!
Jul 19, 2013 | Vacuums
Stops
I had the same problem when I renovated my kitchen. With boxes of stuff everywhere it was impossible to use Roomba. When I tried to use it again a few months later, it would stop after only a few minutes work. I had to buy a new battery which cost in excess of $100. Its better to loan it to a friend to be used than to put it into storage.
Apr 30, 2013 | iRobot Roomba 530 Robotic Vacuum
Irobot roomba 500
If you're sure the battery contacts are clean and the battery really is charged, then there is faulty circuitry within the Roomba that would have to be repaired or replaced.
Confirm that the battery is inserted with the metal contacts down so they make contact with the spring terminals in the battery compartment.
Visually confirm that the metal contact plates on the battery pack, and the spring terminals in the battery compartment are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
Visually confirm that the metal contact plates on the Roomba, and the spring terminals on the docking station's home plate are clean and shiny. If not, wipe with a clean cloth or paper towel, its OK to use a little water or rubbing alcohol on the cloth, if needed, and then dry it.
If you have a volmeter, measure the voltage between the contacts on the battery pack If it isn't something in the neighborhood of 14 volts and is 11 volts or less, the battery isn't fully charged.
Reinstall the battery.
For the moment, please connect the power adapter directly to the Roomba rather than the docking station to eliminate one possible faultly connection.
If the battery wasn't fully charged, or you weren't able to test it, try to charge the Roomba and then retest the battery voltage if you can. If the battery voltage was higher immediately after charging, but didn't get to 14 volts, the charger is good, but battery needs to be replaced. If the battery voltage was unchanged after attempting to charge the Roomba, the charging circuitry may be faulty. If there was no light patterns when you tried to charge it, and it was plugged in to a good outlet, then the power adapter or charging circuitry is definitely bad.
If you have no voltmeter and you cleaned the contacts and tried to charge the Roomba and it works, use the Roomba and then recharge using the docking station and see if it was just dirty contacts or it won't charge through the docking station. If it didn't work, you'll need to figure out if its the battery, the charging circuitry in the Roomba, or the power adapter. If there are no lights when you try to charge the Roomba, then Either the power adapter or the Roomba power circuitry is defective, but without a voltmeter you can't find out which one, and there's no way to know if the battery is good or bad, but you know Roomba wasn't trying to charge it. If there are lights when you try to charge the Roomba, then at least you know the power adapter is good. Unfortunately, without being able to test something there's no way to distinguish between a charger that won't deliver a charge to the battery and a battery that won't accept a charge. If you want to take a guess then a bad battery is more common and less expensive to fix.
Jul 07, 2012 | iRobot Roomba 560 Robotic Vacuum
My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
If this helps, please come back and rate my suggestion!
Jun 06, 2011 | iRobot Roomba 530 Robotic Vacuum
My roomba 560 approaches the dock and attempts to dock. However, it never seems to align correctly and backs out. This is a continuous process. It simply will not dock at all. Any suggestions?
Check the connector on your ROOMBA, there is a switch that open the ground when you connect the charger direct to the ROOMBA and a lot of times it get stock and remain open. Using a small screwdriver press the metal plates to force to close.
Oct 08, 2010 | iRobot Roomba 560 Robotic Vacuum
Jun 18, 2009 | Roomba Robotic Floor Bagless Vacuum
Oct 29, 2008 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba 4210 Bagless Robotic Vacuum Logo
4,525 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
