Question about Weedeater Weed Eater Ght225 22-inch 25cc 2-cycle Gas-powered Hedg
Weedeater ght220 How do i put the handle back together
How to put the housing back together on my homelite weedeater
Try this: https://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
May 13, 2017 | Homelite Garden
Unsieze a weedeater motor after using regular gas
Even if you are able to "unseize" it, it may not run afterwards. The reason you NEED to add oil to the gasoline is because that is the only lubrication the engine gets! You can try to unseize it by removing all of the remaining gasoline from it and putting in ONLY some 2 cycle engine oil. Then you will need to attempt to turn the engine shaft back and forth using the weedeater feed spool as a lever handle. IF, and I say if it breaks loose you may not have sustained alot of damage. If it doesn't...
Jan 10, 2013 | Garden
Hey Im the one that was asking about featherlite weedeater starting problem and you suggested a carb kit. How easy is that to put together? Im a novice woman do you think I could do it?
Welcome to fixya!
I'm a woman too and I learned by trying. Don't let anyone tell you you can't do something. Borrow some tools if you don't have any and go for it.
Carbs come with instructions on how to put them together.
If you have trouble, come back here and someone will help you out.
Go for it!
Handie Andie
Jul 16, 2011 | Garden
Hedge trimmer Weedeater GHT220 starts, runs for 5 secs, but will not continue running. 6 years old. Could be related to fuel left in during winter off season and not used. Recommendations to trouble shoot,...
It most probably is the fuel.Empty what gas is in it,remove the fuel line and primer bulb.Clean the line and inside of the bulb with WD-40.Clean the plug too,just for good measure.
Happy cutting.
May 11, 2011 | Garden
Poulan Gas Hedge Trimmer GHT220 shuts off after 10 min.
your ing. coil is breaking down as it heats up needs to be replaced
Aug 05, 2009 | Ryobi 26CC, 22 In. Hedge Trimmer
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Weedeater Weed Eater Ght225 22-inch 25cc 2-cycle Gas-powered Hedg Logo
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Jerry Kramer
Jerry Kramer
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
