LaCie electron22blue monitor. Power supply board module fuse blows when power button is pressed. Replacement fuse also blew out. No visible damage to power supply components, such as scorch marks or exploded components.
Can you help, please?
Comments:
Jan 22, 2009
- There is no visible damage on the PCB or on any of the components. No burn marks. Any other ideas?
There is definately a shorted component that causes the fuse to blow.
Nomaly the ceremic capacitors are the cause of the problem. Check to
see if there is visiual dark or burnt ceremic caps with label sameting
like this "SCK 083" near the fuse area and change it. Hope it
helps,cheers.
my monitor screen goes black it lights up about half the scree when i first turn it on then blinks...
(More)
my monitor screen goes black it lights up about half the scree when i first turn it on then blinks like a light bulb that is not screwed in all the way then goes completly black acer al2002w
