LCD show right picture for 1 second when I turn on, then go black
I got this ViewSonic VG710B VLCDS23719-5W 17" LCD Monitor from Ebay.com. when I connected with my computer, every time when I turn on the monitor, the screen show correct information for about 1 second, then go to black screen. I need to turn monitor off, then turn on again, same thing will repeat. I do not know how to open this monitor to take a close look inside. any suggestions are appreciated.
Thanks
Liwen
  • Anonymous Mar 17, 2009
    Exact same problem
  • 112 Answers
You need to read the monitor manual . other wise you can contract the dealer.
Posted on Jan 22, 2009
Unit turns on and displays Screen but then shuts screen but power light stays on. This happens all the time
The 12vdc AC adapter is putting out 12vdc when attached to the monitor?
The problem is more likely to be in the backlights inverter board, please check the fuses and voltage (12vdc) feeding the this board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | ViewSonic VG710b 17" Flat Panel LCD...
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
My monitor goes dark after 1 second and won't come back until cycled off and on again
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a second, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic VG710b 17" Flat Panel LCD...
Sudden black out/ shut off from time to time
Sounds like you have a video card issue. You will need to replace your video card in your PC..Also, you can take another monitor and hook it up to your PC to see if you get the same results
May 14, 2009 | ViewSonic VG710b 17" Flat Panel LCD...
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic vx715 17" lcd turns on but goes dark in like 5 seconds
You need to replace your Inverter board or replace the 2 black caps on the power supply board wich are labeled 1000uF 16v ELITE. that will cure your problem. Glad I Could Help!
Apr 08, 2009 | ViewSonic VX715 17" LCD Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
