Question about Watches
Test message from qa
This i a test message from q
Uniden 6.0 dect messege light will not stop blinking
resetting the voice message indicator
if the voice message indicator icon remains after you check your messages , you can reset it
1---with the phone in standby, open the menu
2 select the global setup, then select the VMWI reset
3 select yes
the flashing light will then go to full on as in the phone standby situation
refeence from the uniden user manual
May 16, 2017 | The Watches
Free apple watch for testing it
Free apple watch Melissa, Promotion may be over, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Product Testing
How to get free Apple Watch UK Evening News
Product Testing
free apple watch product testing joel apple watch review
Product Testing
Mar 28, 2016 | Watches
Does t. woods watch require pressure testing w/ battery replcmt?
As long as they don't charge you $40, it should be free. Having said that my machine for testing water resistance cost almost $5000. I have to recoup that somewhere. Now you know why it cost so much. Does it require testing, no. But kon't come crying to me your watch leaked and I was the last to open it. I told you it needed to be tested but you didn't want to spend the $40. That is the view from the other side of the bench.
Jun 22, 2012 | Tag Heuer Tiger Wood Golf WAE1111 Watch
FR60 garmin watch error message
No solution. I just tried to change my battery yesterday and am receiving the same message. If I get a resolution I'll post it. Just wanted to let you know you're NOT alone!
May 06, 2012 | Garmin FR60 Wrist Watch for Men
Can I swim laps w/ my ebel 30 meter watch? The watch has 4 screws on the back and the crown does not screw down.
Thank you for contacting FixYa.
Water Resistant is a common mark stamped on the back of wrist watches to indicate how well a watch is sealed against ingress of water. It is usually accompanied by an indication of the static test pressure that a sample of newly manufactured watches was exposed to in a leakage test. The test pressure can be indicated either directly in bars, or (more commonly) as an equivalent water depth in meters (in the United States sometimes also in feet).
An indication of the test pressure in terms of water depth does not mean a water resistant watch was designed for repeated long term use in such water depths. For example, a water resistant watch marked at 30 meters depth cannot be expected to withstand activity for longer time periods in a swimming pool, let alone continue to function at 30 meters under water. This is because the test is conducted only once using static pressure on some of the newly manufactured watches. The test for qualifying a diving watch for repeated usage in a given depth includes safety margins to take factors in account like aging of the seals, rapidly changing water pressure and temperature, as well as dynamic mechanical stresses encountered by a watch. Also every diving watch has to be fully tested for water resistance.
Hope this helps.
Jewel
Sep 02, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
I purchased a watch that is water proof chronological. *spelling. It is set on the 24 hour setting and I need the 12 hours. How do I do it?
Press the "mode" button and you will eventually come to a message that says something like "24H".
Try pressing one of the other buttons to change the message to "12".
As I haven't seen your watch instructions, you may have to experiment a little!
Feb 14, 2010 | Watches
How to remove back for battery replacement - 19 year old seiko wristwatch. numbers on back: 5423-8229 & 041115.
This is a little tricky, I think this has a screw on back. It takes a two or better a three prong tool to remove back. A new seal shoud be on hand to replace this. Watch should have a consumption test and a min run voltage test, if either of these fail a new circuit board or movement should be installed. Take it to a good watchmaker and they will clean the outside before opening and do a water resistance test after assembly.
Jun 13, 2009 | Seiko 0512037FA Wrist Watch
Barometer ERR message on Casion 2271
here is the link for very complete manual:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2271.pdf
Download it and follow the instructions how to set and reset the altimeter and other features of your watch. Use zoom or magnifying tool, as the document originaly has tiny script.
Do not forget to rate please.
Feb 09, 2009 | Casio PRG-40T-7 Pathfinder
Wrist net AU4004
Sooo.....request service.
Aug 25, 2017 | Fossil Watches
Watches Logo
12 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
