Question about RCA F32450 32" TV
I was given a sony dvd player. Need help.
When I put disc in after a few seconds it says "no disc". What can I do? Have no manual. Thanks NORMA
  • 233 Answers
The DVD rom drive / laser has just gone bad. You can open up the dvd player and see if the entire drive has a part number, and try to google it from there to see if you can order it..
Posted on Jan 21, 2009
Dvd's won't play on my sony dvd player
If making a noise the issue could be in the mechanism and or the motor that spins the disc---unless it is a real expensive and fairly new unit it would be better to just replace it.
Apr 16, 2012 | Sony Televison & Video
Bought H1080/XEU dvd player - have Sony 1080 TV - are they compatible? Picture keeps stopping for few seconds and then resuming.
Looks like it is the problem with the DVD disc / media source. Replace the disc with another disc. Last but not least.. why dont you try connecting the DVD player and TV via HDMI cable? Sometimes older cables may cause video drops .. just guessing anyway!.
Mar 05, 2011 | Samsung DVD-1080P8/XEU DVD Player
My Samsung Blu-Ray player won't play ANY DVD. Sign on screen says Disc cannot be played..with no other explanation. It's a brand new, never played BLu-Ray disc. I have a BD P1500 Samsung player attached...
I hope our talented expert would have given you helpful and correct info in chat session from related service manual, feel free to ask further help if required.
Sep 30, 2010 | Samsung Televison & Video
Manuals for sony dvp-ns57p
please check the link below:
on the bottom of the page after the description, you will find the Owner Manual.
please check it, it should give you all the solutions you need.
thank you.
May 18, 2010 | Sony DVP-NS575P DVD Player
You may need to clean the DVD player's lens because it hardly reads the discs that is why you are experiencing that problem. If you have a disc cleaner, try playing it; having it spin for like 30 seconds will clean the lens. If this does not work, then you may have to manually clean the lens by opening the DVD's casing and unscrewing the plastic cover that protects the lens inside. Get a q tip or a cotton bud and damp it in an alcohol. Gently wipe the surface of your lens and let it dry for a few seconds. The return everything back and play those DVDs again.
Good luck and hope this helps.
Dec 12, 2009 | Sony SLV-D380P DVD Player/VCR
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
RCA F32450 32" TV Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
