Question about Samsung 3 Pack Fridge Water Filters Lg Bosch Ge Daewoo
DSRS5KGXCFGS Serial number 429076
Fridgeaire upright freezer no serial numbers to be found anywhere was trying to adjust temp on front of door outside now unit says of and is not running how to turn back on???
tough one
i guess its a frost free
turn the thermostat adjustment to on /highest temp temp ...then off /lowest
till the compressor kicks in
if not suspect faulty digital display panel or thermostat itself
agreed no serial number etc
makes it very hard to help you fix this
http://kitchen.manualsonline.com/manuals/mfg/frigidaire/frigidaire_freezer_product_list.html
Oct 11, 2016 | Frigidaire Freezers
What is date of lane cedar chest style 481939 serial no.145280
According to Lane, your cedar chest was made 8/25/14.
Usually Lane cedar chests have serial numbers that are stamped or applied to the bottom of the chests.
You can read the serial number BACKWARDS to determine the production date.
For example: serial number 753150 would have been produced on 05/13/57.
Some chests may also have an extra digit which denotes the plant location.
For example: serial number 2557121 would have been produced on 12/17/55 in plant #2.
Oct 06, 2016 | Freezers
How do i find out how old a freezer is?
Search online to find the manufacturer's website. Call or email them. Be sure to have the model number and serial number. They should be able to help you.
Jan 07, 2015 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Hoshizaki troubleshooting
Need entire Model number. usually ends with a number. Serial number would help too.
Jul 17, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
I have a BEKO CDA539F and notice that there is one with an X attached to the end of the code that is amongst the recall models. I asssume that my fridge freezer is safe. Am I correct?
From what I understand, you are safe if your serial number does not match the ones in the list exactly. That said, the information I have is from knowledgeable sources but NOT from BEKO, who have failed to answer their 0800 incident line or reply to my mails for 4 days now (By coincidence, while I provide a lot of technical help on this forum, I also have a BEKO fridge that IS on the list).
I would go to their site and send in a mail via the facility they offer there. I imagine that at some stage you will get a confirmation that all is OK with your fridge, but I would want to cover the bases if I was in your position. For convenience, the original article I wrote with the BEKO website listed in it is reproduced here for you:
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including most importantly, BEKO's own website, the MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
The fridges affected were manufactured between January 2000 and October 2006. After shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008. The first 2 digits of the serial numbers indicate the year of manufacture, so if your serial number doesn't start 00, 01, 02, 03, 04, 05 or 06 you don't even need to check.
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
The site also provides a mail address and a UK Freefone number that you can call (Though I've tried the number and it keeps cutting me off!! I presume they are swamped with calls)
Jul 09, 2011 | Freezers
How old
May I get the model and serial # to help you find out the year.
Jul 02, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Where is the serial number on Frigidaire FVE1415
on most frigidaire freezers the model and serial tag is on the inside left hand wall. if it is not there it mya be on the back of the unit. the serial number generally starts with 2 letters and is 7-9 characters long hope that helps thanks Peyton
Mar 03, 2009 | Frigidaire Freezers
Need defrost unit
Call Hussmann Corp at the number I posted. Give them the model number and serial number and they should help you out. There is also a fax number if you wish to use a fax.
Jun 11, 2008 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Samsung 3 Pack Fridge Water Filters Lg Bosch Ge Daewoo Logo
70 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
