Wondering if when external antenna is installed and rg6 coax is
Plugged into video outlet will HD reception be automatic from those stations broadcasting in HD ?
  • 3 Answers
Channels are digital so you don't have to worry
Posted on Jan 21, 2009
Only 2 FM stations working. I have an Insignia Stereo receiver. At first, we could get all of the FM stations, then all of a sudden we can only get two. The antenna has not been moved from where it or
If you have an external antenna, check you antenna connections.
Weather can change your reception. Are the stations you can hear local? within 30 miles? Or is there an amplifier on your antenna system? It may have quit functioning. if you have cable TV you might want to hook up your stereo to that system, you will need a 75 to 300ohm adapter that you can pick up from an electronics store or online.
(coax to twin lead)
Sep 27, 2014 | Audio Players & Recorders
Herringbone RFI in nearfield from adjacent LCD TVset both on Analog/Digital 195 - 229Mhz.
Your problem is related to a low level input and a source of interference that is close by. Perhaps the problem could be resolved by the application of a better higher level signal delivered from a roof antenna through a good grade of RG6 coax cable to the input as coax will reject a lot of interference and at the same time deliver a more usable signal to the set. Antennasdirect sells good HD TV antennas and you may want to
consider a distribution amplifier if several sets are connect to the single antenna- I am supplying 4 TV off one antenna.
Aug 09, 2012 | Televison & Video
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    Improve reception
    HI there,
    Well Yes you can improve the reception, please follow the below steps -
    Improve FM Radio Reception -
    1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
    2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
    3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
    4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
    5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
    Improve AM Reception -
    1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
    2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
    3. Plug the radio into a different AC outlet.
    4. Move the radio closer to a window.
    5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
    6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
    7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
    Good Luck!!
    Thanks
    Dec 29, 2009 | RCA RP5430 Clock Radio
    Trying to convert rg6 to component, how do i , what adapters do i need
    RG6 is usually antenna coax, which carries multiple radio-frequency signals. If you want to convert a signal coming in over RG6 to component video, what you need in the middle is a tuner, such as a digital TV tuner (e.g., the type the government sent us all coupons to buy before the big digital switch earlier this year).
    Nov 08, 2009 | L-Com RG6/U Bulk Spool, 1000ft (RG61K)
    Prong on RCA antenna cable too large for spot on Toshiba vcr/dvd
    Hi, You need to look on the cable itself to see if it is an RG58 or RG59 or RG6 or RG9. On an RG6 cable the center conductor is larger than on an RG58, The RG6 cable is used for incoming cable, satellite ect. An outside antenna is not usually equipped with an RG6 unless it is of the new HD variety, which is meant to go to one of the newer tvs. You can remedy the problem a couple of ways, use the ant out on the tv if you have one or use an adapter that fits 2 coax cables together and use a RG 58 jumper from the adapter to the vcr. Good Luck!
    Feb 15, 2009 | Toshiba Televison & Video
    Dish Network HD Monitor HD 40-300
    I have a Dish Network HD40-310 Monitor. When you turn power on the green power light comes on, then tv makes funny noise, then goes off again without producing any picture. Any ideas how to fix?
    Aug 02, 2008 | RCA Televison & Video
    Antenna for my HDTV
    Special HD or Digital antennas are not required to receive digital stations. A good VHF/UHF antenna should work. Try an amplified antenna for the best reception. Most antennas have a coax type connector which should connect to the ant. in jack on the back of your DirectTV box or to your tv depending how the box is connected to your tv.
    Jun 25, 2008 | Panasonic PT-53WX54 53" Rear Projection...
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
