Question about HP Photosmart C6180 All-In-One InkJet Printer
Copies Hows to print more than one copy of a document at a time.
    Scholar:
  • 97 Answers
Hi grandmabc,
use the copy menu button and u can set the settings.
Regards,  raj_p5983
Posted on Jan 21, 2009
I was copying a fairly large document and at some point the document continued to scan but stopped printing. The memory light is on and the LCD print out reads "printing" but it is not printing.
hello there, Sorry but the question is a bit confusing. Did the document finish copying or it copied half way and stopped? Or you were copying and printing it at the same time?
If you were copying and printing at the same time then the problem is expected as the procedure for printing is considerably faster than the copy process. Simply turn of the entire system either by proper shutdown or by just cutting the source of power to the unit. And this time copy the document completely first before you try printing. This should come up without any hassles.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 04, 2011 | Office Equipment & Supplies
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
When printing, sentences over lap so the document is unreadable. Also it may only print the first line of a document.
I've seen word documents do this sometimes and fixing it has worked differently each time.
1) Open the document and press CTRL + A (select all) on the keyboard and then CTRL + C (copy), then start a new document and press CTRL + V (paste). Save the new document as something different and try printing again.
2) Open the document again and select all and copy again,but this time open wordpad (a different program to Microsoft Word) by going to Start > Programs > Accessories > Wordpad, and paste the text into wordpad. This may change some of the formatting. Now, select all again, and copy, and start a new word document and paste.
Copying the text out of word and back in seems to work more often. Sometimes the best program to copy out to is notepad, but you lose pretty much all of the formatting when you copy back into word.
3) If this doesn't work, you could try to update your printer drivers, and if that doesn't work, as a last resort, you can delete the printer and create it again via the Control Panel > Printers.
May 04, 2011 | Office Equipment & Supplies
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printer prints more copies than indicated. Driver reinstalled multiple times.
I don't know if this will help but I have had similar problems. I would notice that one or two particular programs would print more than one copy and others were just fine. Try checking the preferences on the actual programs. Some programs retain their last qty request and don't change unless you change it. For instance, you request a program to give you two copies of a particular document and everything works fine. Then a day later you are in the same program and need only one copy of a document and you get two instead. This is because there is something set in the program or the preferences of your printing device that causes it to retain the last requested quantity for printing. Next time you print check the print dialog box and see how many copies it is showing will be printed. Hope this helps.
Jun 01, 2009 | Computers & Internet
CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
Feb 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer problem
try to un-install the printer and re-install it again and see if this will work with you
Feb 09, 2009 | Canon Office Equipment & Supplies
Printing old copied images not saved
go to the printers & faxes documents & look for your printer model, now see if there is any pending documents there & delete it.
Feb 03, 2009 | Lexmark X2500 All-In-One Printer
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
