Question about Epson Stylus Pro 9800 InkJet Printer
Clogged nozzles on Epson 9800
I have an Epson 9800 that is a little more than 3 years old. It worked very well up to a couple of weeks ago. I do not print every day but at least once a week. The print quality went way down, showing tiny banding at high resolutions and the colors are off. i.e. I am getting green instead of deep black ect...When I ran a nozzle check, entire lines were missing in the first 2 or 3 colors. Muliple cleanings and a deep cleaning cycle did nothing to help. Just used a ton of inks and filled my maintenance tanks. On auto cleaning, it tries to clear the nozzles by running a few cycles then comes up with a frustrating cleaning error. How do I stop the bleeding!?
I ran accross the Lyson cleaning cartridges product on the web and thought that I would run a supersonic deep cleaning cycle with those installed instead of my inks as I am dismayed by the amount of ink that is being wasted with no result!!
Any advice or suggestions?
Thank you in advance
Ely
  • 3 more comments
  • elytahan Jan 22, 2009
    Replacing the print head is an "easy" albeit prohibitively expensive solution for a printer that is only 3 years old! Is there a way to make sure that it is solely a harware problem?
    Any advice on the Supersonic cleaning cycle with the Lyson cleaning cartridges? (I run Matte black but was shipped a Photo black cleaning cartridge. will it do the job?)
    LYSON Cleaning cartridges. They are used to flush out old inks...
  • elytahan Jan 23, 2009
    Any idea what a new print head for Epson 9800 would cost? does anyone know of a repair facility that can replace the head in the Los Angeles area?
    you mean $1000 !? this is a large format printer!
  • elytahan Feb 05, 2009
    I
    finally got a technician to replace the print head and pump for 1k. So
    after about an additional k in wasted inks, maintenance tanks and
    cleaning solvents, the machine is running like new and I am a happy
    camper once again!
  • Epson Master
  • 19,396 Answers
Before replacing the printhead remove it and soak in isopropyl alcohol or cleaning solution for one or two days. This usually works.
Your printhead is clogged not faulty.
Posted on Jan 23, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my knowledge, not that many suppliers for parts for large format printers not capable service shops. There are however Epson authorized parts distributors and/or service shops. Pls try:
  • Compass Micro, Inc. (503)408-8725 or (800)388-8595
  • Micrologic Systems, Inc. (903)561-0007
  • National Parts Depot (845)469-4800 or (800)524-8338
  • TSAworld, Inc. (770)417-2323 or (800)633-6626
  • Vance Baldwin Electronics (954)723-9191 or (800)432-8542
Should on the otherhand venture into performing the repairs yourself, a Service Manual would be very very helpful.
Pls post back results. Good luck and thank you for using FixYa.
  • 535 Answers
To clean your printer nosel u have take light hot water put the printer nosel on it for some time take a tishu papaer & clean it then try to print if its not work then u have to bue new cardige
    Brigadier General:
  • 3,614 Answers
Here is a a list printer repair center on your Area.
you may contact and consult for any other concern;
Printer & Copier Repair Stores & Service Providers in Los Angeles
    President:
  • 1,990 Answers
Welcome to Fixya! They will work to Clean it Just Fine.
Posted on Jan 22, 2009
    Brigadier General:
  • 5,158 Answers
I'm not sure if i read that wrong... lysol ?
What's on the label of that product ?
Robert
  • Roberta Smith
    Roberta Smith Jan 22, 2009
    I've never heard of that but i can see the chemicals in lysol doing all sorts of damage to the printer.
    Robert
  • Roberta Smith
    Ok my error i just noted i was reading the brand wrong
  • 916 Answers
  1. From inside a software application such as MS Word or Notepad, go to the File menu and click "Print".
  2. Click on your printer in the list to select it.
  3. Click on the "Preferences" button and the "Utilities" or "Maintenance" tab
  4. Locate and run the "Head Cleaning" utility at lease once but no more than 3 times consecutively.
  5. Print a test page.
  • 2 more comments
  • machadojr_fe Jan 22, 2009
    if this does not work here is a manual way of cleaning the print head. Click here
    Try the cleaning cartridge and if it does not work then the print head will need to be replaced.
    Yes they clan flush out old ink and clean the nozzles if they are clogged. If you would like you can check the print head first with the manual print head cleaning guide i had posted to see if it looks worn or not and if it does not use the cleaning cartridge. If it does you will know to replace it and you will already have half the job of replacing it done.
  • machadojr_fe Jan 23, 2009
    Here is a print head for you: Click Here
    As for a repair shop there is a shop called the micro league inc they are located at.
    12436/A Santa Monica Blvd
    Los Angeles, CA 90025
    (310) 450-2708
    Genius:
  • 1,550 Answers
It seems to be hardware failure in your printer . You need to replace the entire print head .
  • 1 more comment
  • SAM ANDERSON Jan 22, 2009
    You have tried all troubleshooting techniques like
    • nozzle check
    • auto cleaning
    This can be the last attempt LEAVE PRINTER ON THEN,
    1 remove ALL ink cartridges and close all covers
    2 unplug power cord from back of printer
    3 wait 4 minutes
    4 plug power cord back in and wait for 10 minutes
    5 when prompted install ink cartridges and wait a few minutes
    click the setup button on the front of the printer scroll down to the tools menu and then run clean print head 3 times and last of all run align printer 1 time.
    if you still have problem then you need to replace the print head there is no othe option .
  • SAM ANDERSON Jan 23, 2009
    It will cost around $100 .
Epson RX620 yellow lines/blocks on page
Try to print the nozzle check, and see what your out put is like.
If it is not giving you a regular pattern, then have the nozzle
replaced. Most times when the nozzle is clogged with ink, you
get such out-puts. So follow this steps.
How to print the nozzle check:
1. Press the Setup button.
2. Use the arrow buttons to select Nozzle Check, then press the OK button.
3. Confirm the message on the display, then press the OK button to print the Nozzle Check.
Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps
Nozzle check pattern with gaps
Apr 14, 2009 | Epson Stylus DX6050 All-In-One InkJet...
I just bought new ink and nothing prints clearly
If it hasn't printed anything for a couple of years then the print heads will be severely clogged with dried ink. Epson recommends printing a page or two every month to keep the heads clear. You need to try cleaning the print heads, its unlikely that one or two head cleans will clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink, have some new ones ready.
If you need to know how to do head cleans & nozzle checks, the user guide can be downloaded from Epson here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVFHuU002FlmukU002FlwLFmittYG0bE9gMlZoUifYkU003D
Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 01, 2009 | Epson Stylus C86 InkJet Printer
Brand new Epson black ink cartridge won't print
Leaving an inkjet for two weeks with an empty cartridge is a definite way to get clogged printheads. Try doing 4 to 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with anozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
Hope this helps.
Mar 25, 2009 | Epson Stylus Photo R300M InkJet Printer
I have an Epson 4000 which has a clogged nozzle
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Feb 23, 2009 | Epson Stylus Pro 4000-PS InkJet Printer
Clogged print head
Greetings,
There are a few different solutions floating around the net for Epson nozzle cloggging.
Here are a couple of links I have found helpful:
1. http://www.atlascopy.com/newsletters/How_To_Clean_Clogged_Inkjet_Print_Heads.htm
And this one goes a little deeper:
2. http://www.ehow.com/how_2078853_clean-clogged-inkjet-print-heads.html
This one was also helpful:
3. http://eddiem.com/photo/printer/unclog/unclog.html
I used the soaking in hot water and it worked perfectly.
It took about an hour to disassemble the carriage and head and put back together, but it is worth it.
Good Luck,
Dean.
Nov 06, 2008 | Office Equipment & Supplies
Rebuild Epson R1800?
You could run head cleaning from the driver a few times and see if the nozzles start to clear out. If you send it in for repair they run a solution through it that is supposed to clean it out. If the solution doesn't work the head is like a $400 part.
Oct 04, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson 9800 has continuous drop out...
I have always had best success using manufacters ink
Sep 30, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson cx6400 ink problem
The ink nozzle may be clogged. You may be using refill ink not from the original epson ink. Try cleaning the nozzle assembly or the printer may not be usable.
Feb 09, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Oct 10, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9800 InkJet Printer Logo
123 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
