Question about Scotsman Refrigerators
Scotsman Self Test Failed
Scotsman cm3 does not harvest
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Condenser fan not working on a scotsman prodigy ice machineC0830SA
Turn the machine off, find the leads going to the fan motor and remove the leads and check continuity through the fan motor with an ohmmeter. If you get 5 - 15 ohms resistance, the motor is ok and it is the control card. If 0 or a high resistance the motor needs replaced.
Jun 25, 2013 | Scotsman Ice Maker With Bin Cube Style...
Scotsman sce275 making ice too thick
carefully adjust the ice bridge thickness screw at the top no more than 1/8 of a turn counterclockwise in between freeze cycle until desired thickness is obtained. clockwise gets thicker and counterclockwise thinner.
Apr 12, 2013 | Scotsman Ice Machine - 290lb...
Dell Dimension 2400 What is Targeted Read Test WHD-20-2RQ and Smart Short Self Test WHD16-FTD and how do I fix it if it said they failed
These are results of two sections of Dell Diagnostics tests which can be run by pressing F10 at startup.
You would have to watch them run to see what has failed during the test.
From Targeted Read Test WHD-20-2RQ failed, could be failure to read RAM (memory), CD/DVD Drive, or Hard Drive.
Something failing within Smart Short Self Test WHD16-FTD could literally be anything within the computer, without seeing what has actually failed during the test.
Sep 05, 2011 | Dell Dimension 2400 PC Desktop
It says harvest time maxed and no ice detected what tells machine to stop havest
Hi and welcome to FixYa, I am Kelly.
Download this manual and read page 19 carefully.
http://www.scotsman-ice.com/docs/uploaded/sct/manual/275m.pdf
I think you have a thermistor problem. But... there are several things that will cause the 8 minute max harvest time error. See the diagnostic lights chart on page 19.
Diagnostic Lights:
There are two RED diagnostic lights, one to indicate a water problem, and the other to indicate a refrigeration problem.
Both On all the time / Check for thermistor set unplugged or failed
Additionally see the troubleshooting chart on page 27 "Unit OFF for a harvest problem"
Also make sure to read page 15. The thermistor inputs are on connector #5 left side of the controller
Resets:
Note: The machine may be reset and restarted by
pushing and releasing the Off push button switch,
and then pushing and releasing the freeze push
button switch.
Lastly after a RESET read the initial start up procedures on page 12 right side with regards to the harvest cycle steps 1 - 8.
Thanks for choosing FixYa,
Kelly
Mar 10, 2011 | Scotsman Ice Machine - 290lb...
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
May 23, 2010 | Scotsman Ice Machine - 290lb...
Refrigerators Logo
109 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
