Question about Singer 2250 Tradition
Wheel on sewing machine is jammed - Singer 2250 Tradition
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
Motor runs machine jams, wheel hard to turn
Unless you are a qualified service technician, take it to a technician for repair. Trying something yourself may cause more harm.
Feb 24, 2015 | Sewing Machines
How do i free a jammed sewing machine wheel
oh, there has got to be a reason. Is the needle stuck down, did you take the bobbin case out? Is the belt tight enough to move the wheel? need more info
Aug 10, 2014 | Brother Industries, Ltd Brother Sewing...
Sewing machine is jamming on first turn permanently
Your bobbin may be in backwards. Is it possible to put it in either way?
Mar 01, 2014 | Singer Co Singer Talent 3321 Sewing...
Elna SU purchased in 1977 jammed; rotating wheel is unable to move forward
it sounds like the machine needs to be serviced at a sewing machine
shop
May 05, 2012 | Elna Sewing Machines
I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
Mar 03, 2011 | Singer Sewing Machines
The thread hangs up inside the bobbin holder
Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Jun 10, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
Singer 2250 Tradition Logo
35 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
