Question about Sony Icdpx820 Digital Portable Ic Audio Voice Recorder 2gb Icd-px820 Mp3 Black
Light flash re then green
Old batteries were worn out with just the slightest corrosion at + tip. new battery just causes red / green alternating flash but no operation
4 Suggested Answers
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
  • 65 Answers
SOURCE: I have no manual for my DSC-W70 & a red light
Go to www.retrevo.com and download a manual ted10
Posted on Apr 20, 2009
BLAZZ81
  • 281 Answers
SOURCE: ps3 the light goes Green,Yellow,Flashing Red
this is called the yellow light of death,, ylod..
Sorry to be the one to tell you this but its not good!!
A main chip/chips got to hot to many times over time...[CPU,Video and and/or RAM IC's..
This can be fixed but if not done right it will not work for long or make it unfixably
I would say send it back to sony,,
if your willing look up ylod fix and try to fix your self,,
refloating the chips do work if its done right,, be careful if you try, and do alot research on ylod first!!
Posted on Apr 07, 2010
I have a logitech m bck135. I replaced the batteries as they were dead and once replaced, green and red light continuous flash. I cannot use the mouse at all, nor can I shut it off. It just keeps flashing...
Must be short circuited somewhere, this might be caused if your old batteries wasnt alkaline ones but just normal ones, if a normal battery's life ends then the battery releases toxic acids that can blame your circuits, you can open your mouse and check inside if any old batteries acid liquid cause any damage to the circuit, it will look like corrosion spots, clean the corrosion dirt using alcohol and water and let it dry, after that check the connections of the circuit if any is broken, in that case use a soldier gun and lead wire to resolder broken lead connections.
Jul 18, 2011 | Computers & Internet
Red and green light flashing on 5 of my bl11830 battaries and they will not take a charge
If you put a battery on your charger and both red and green lights flash it is indicating that battery is defective. There may be a short in the battery or they just may be too old and worn out to charge anymore. If the charger is reading the battery as defective it will not charge the battery. The only fix is to buy new batteries.
Jan 20, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Lights go dim then battery lights comes on then transmission light comes on already changed battery and altinator
Hello these cars were know to have a wire that runs from the positive on the battery terminal to the alternator that would corrode and cause this problem. The best way to find the problem is to remove the air cleaner box where the air filter is and then you will see the top of the battery. You will see a wire that is hooked into the positive on the battery terminal that should be green in color and if you follow it up it turns red. The green part of the wire is usually less than 6 inches. Right where the green and red wire connect together is where the problem is normally. You will probably see corrosion there. Cut the corrosion out of the wire re-splice it together and make sure any bare wires are wrapped up good with electrical tape. This should fix your problem. 4 thumbs up is appreciated if this helps.
Jan 15, 2011 | 2000 Dodge Intrepid
I replaced battery first,...... then alternator on 2005 Focus. altenator was a bear to replace,.....still have(red) battery warning light,....... Thinking wiring,..corrosion...or tension pully is...
the alternator is a doodle to change ,when you know how ?? was it a new recon unit or a secondhand scrapyard job---- check for power to teh large terminal the start engine and disconnect neg battery terminal if engine stops alternator fault ,if engine keep running but red light still on then its warning light control fault which is built into alternator so change alternator .
Sep 15, 2010 | 2000 Ford Focus
Camera wont charge. green light comes on for a second then a red light flashes and then goes out
This normally indicates a battery problem. Remove the battery and wipe the contacts (battery and camera) firmly with a dry cloth to remove any corrosion that may have built up on them. Heavy corrosion may require cleaning with a fine wire brush, steel wool, or sandpaper. After cleaning, remove any debris that may have fallen into the battery compartment, then insert the battery and connect the camera to the charger. If the green light stays on, the problem is gone and you can charge the battery for several hours and then use the camera. If the red light comes on, it's likely time to replace the battery - especially if it's more than a year old.
HINT: Always remove the battery if you don't plan to use the camera for a week or more. This will prevent corrosion buildup and extend both battery life and camera life.
Bill B
Apr 25, 2010 | Kodak Easyshare M753 Digital Camera
When i start my camera it turns the light green to red and shuts off immeditaly
Green light indicates good battery strength. Red light indicates that your camera has an insufficient or low battery power level and will be automatically powered off. . To continue using the camera, please change your batteries to new ones.
Please note that:
  1. If you don’t intend to use your camera for an extended period of time, please remove the batteries to avoid battery leakage and corrosion.
  2. Do not mix old and new batteries.
  3. Alkaline batteries are generally recommended.
Feb 13, 2010 | Vivitar ViviCam 5355 Digital Camera
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
89 Honda Accord Battery Light is On
The FuseLink is blown. It is a 100 AMP in-line fuse on the red wire from the alternator.
Oct 05, 2009 | 1989 Honda Accord 4 Door
The charging light flashes alternately in green and red color, charging is not possible.
You have defective batteries. Either they are old and used and can no longer take a charge and should be replaced, or they have a problem not allowing them to be charged.
If batteries are new, seek replacements. If old, time to buy new batteries.
If this happens with several batteries, and even new ones, your charger my be faulty.
Feb 27, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Sony Icdpx820 Digital Portable Ic Audio Voice Recorder 2gb Icd-px820 Mp3 Black Logo
95 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
