Question about Panasonic PT-47WX49 47" Rear Projection Television
Does anyone have a service manual?
It turns off 3 seconds after i power on
  • 1 more comment
  • Gene'O Turney Jul 04, 2007
    my email is [email protected]
  • psualum23 Nov 19, 2007
    I have the same issue. It powers on and then turns off after a few seconds. Any thoughts?? Thanks....
    Email is [email protected].
  • Anonymous Nov 19, 2007
    It seems like a problem in the high voltage power supply.I do not have a service manual but everything appears to fire up until there is a short burst of video as if there is a crow bar shut down..maybe a shorted capacitor any how it gives the appearance that all is well until the current demand shuts it down.
    President:
  • 3,130 Answers
Whats the e-mail address?
Posted on Jul 03, 2007
  • Larry  Dillon
    Larry Dillon Jul 05, 2007
    Dead thread noggin Sorry
  • 944 Answers
I think you may have seen this site, but just to be sure; http://cmpalmer.blogspot.com/2006/11/fix... It looks very useful for you. these guys have a service manual and supplement for sale; https://www.manualsparadise.com/ShowProductsForModel.do?model=M77759179 also I saw a blog saying that you can actually order these from panasonic direct - haven't tried it myself Hope this helps :)
6ya staff
SOURCE:
Hi can anyone help correct error code E7 10 on asharp AR 5516S copier
It's one of those dealler faults..
"Turn off the power switch, wait about 10 seconds, and then turn on
the switch again. If this does not clear the message, write down
the code (Main code and sub code exists.) that appears and then
unplug the power cord and contact your authorised service
representative. Tell your authorised service representative what
code appeared and the circumstances under which it appeared."
from the following link..
https://www.manualslib.com/manual/601912/Sharp-Ar-5516.html?page=74#manual
Feb 26, 2017 | Office Equipment & Supplies
When turning the unit on, powere button changes from red to blue for around 3 seconds, then goes to red off again. Anyone help?
Its due to the complaint of its Power Ballast unit ( Power Control Board). So please contact any one of the service centre in your area.
Sep 29, 2015 | Acer P1100 - DLP Projector 3D
I bought this control and threw out the manual I didn't realize I needed one it's model no: URC 11-2981 R00 Anyone know how I can use it
Hi Please check the have you inserted 2 battaries (AAA
(x2)).
Search method:
1) Press TV button.
2) Press Magic button and hold for 3 secs
3) Now press 991
4) now press power button
5) now press CH+ button until your television turns off. This may need to press many times.
6) Once turns off, press magic button.
7) Now press Power button. some times TV may not turn on, at that time press any other button.
Volume Lock:
1) Press magic button and hold for 3 seconds
2) press 993
3) press TV Key.
If you require more option please post which option require to you.
Feb 10, 2013 | Televison & Video
What does a 2-3 dignostic code on a Mitsubishi 55819 mean?
2blink-then 3 blink---------deflection circuit problem
It is a little misleading but means something in Horizontal or high voltage circuit (covers a lot of area inside the set) is bad.
Going to need a service manual, etc to try to track it down.
Entire chassis for this set can be removed====called a light box.
May 28, 2012 | Mitsubishi WS-55819 55" Rear Projection...
I have a Workcentre 5050 that doesn't recognize the network controller. Does anyone have any advice or an installation Manual?
1. Turn machine off 2. After it has completely powered down, unplug the power cord from the wall. 3. Go back to the front of the machine and turn it on and then back off again (remembering to leave it UNPLUGGED from power.) 4. WAIT 60 SECONDS (Very important) 5. AFTER 60 seconds plug it back into the wall and turn it back on.
If problem persists call for service.
Hope it helps!
Mar 22, 2011 | Xerox Office Equipment & Supplies
Cd player doesn't work
This is doc-fix. The C D motor is supposed to spin spin, at all times when selection. then the C D record makes selection.
in that sequence.
See if motor spins by finger twirl? Is it turn 3,or 4 turns?
if it is binding on the black plastic, then that has to be corrected. if the motor is getting no power (electric power)
then there will be no spinning. need a diagram , showing how
motor power goes into the C D HEAD TO MEASURE VOLTAGE???
IN-HOME JUKEBOX REPAIR 6362273300
Apr 27, 2009 | Audio Players & Recorders
I did a Service A on my mercedes c350. How do I reset the display
Turn the key on and turn the wheels lock to lock all the way left and right. This should clear it.
Mar 29, 2009 | 2008 Mercedes-Benz Mercedes Benz C Class
PANASONIC PROJECTION MONITOR TV
Usually 3 blinks means convergence,however it should continue to blink. Not shut off. You will probaly need a service manual you can get one through this link for 10.99 along with free unlimited support. If you choose to get your manual you will have to go back to the site and request that they email it to you instead of mailing it out. With your manual they will also email instructions on how to obtain your free support. . Youre probaly looking at a regulator that feeds the IC. I am one of the support techs at servicemanuals also. Heres there link,
http://servicemanuals.vstore.ca/
Jan 15, 2008 | Panasonic PT-53TW53 53" Rear Projection...
RCA Television D52W14
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Jan 08, 2008 | RCA HD50LPW175 50" HDTV
VCR automatically goes into standby mode
If this unit shuts down after you turn it on, it is going into stanby because the microprocessor is not seeing the proper pulses from the mode switch. this could be due to an out of time mechanism because of a broken gear, bad mode switch, the loading basket is out of time or broken, or the capstain motor or the cylinlinder motor is not sending the PG and FG pulses to the microprocessor. These can also be due to a power supply voltage missing. You can check the voltages with a service manual and make sure they are not low. You will also need to get the mechanism manual and check the timing of the mechanism. Then check the mode switch you can get a manual from here http://www.servicemanuals.net/results.aspx?brand=15&model=HRS&type=SM&pos=281 Good Luck
Mar 21, 2007 | JVC HR-S9900 S-VHS VCR
Panasonic PT-47WX49 47" Rear Projection Television Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
