Question about Refrigerators
Kscs25inss00 not cooling - Refrigerators
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
MY Kitchenaid model KSCS25INSS00 refrig ice maker is only producing crushed ice...no cubes...
There a button on the control panel label "cube ice" if you push this it will remove a gate up in the front of the ice make. If it not working. Remove the ice tray and you will see long rod on the ice tray. Move the rod back and forth afew time. Also, on the back wall behind the ice tray is a small latch, make sure that this latch is free to move. There could be ice on it remove the ice. Then reinstall the tray. GB....stewbison
Aug 23, 2011 | KitchenAid Refrigerators
Freezer is cooling, refrigerator not so cool. There's no air circulation for either side
Lets have a look into the rear of freezer and see if ice or frost is beginning to build up. Loss of air flow is usally noticed fist inside the fresh food compartment. Your model has a control board=> 2307037 Control Board I would like someone to unplug refrigerator and inside the fresh food section behind your control panel you will find this board. When they go bad things like this begin to happen like defrost and fans not turing on when they should.
sea_breeze_221.jpg Look over both sides of the control board for signs of heat damage. They sometimes show no damage and are bad. That is where I would start by checking the board. If fans are running poorly that is also a sign that the board and the fan motor may be bad. Here is the boards location=> KSCS25INSS00_Control_Parts The other area to check will be behind the rear wall of your freezers rear panel where you find the defrost heater=> 2210737 Heater, Defrost and defrost thermostat=> 2315504 Bi?Metal, Defrost If you have any questions I will be here, Thanks Sea Breeze
KSCS25INSS00 Repair Parts.pdf
Jul 17, 2011 | KitchenAid Superba Architect KSCS25INSS...
The handle of my side by side Kitchen Aid refrigerator is loose. The model number is KSCS25INSS00. It has circular open holes on the handle, no screws? How do I tighten it?
Use an allen wrench (hex) to remove loosen the set screws in the two handle holes. Once removed, tighten the mounting lug. Replace the handle and tighten the hex set screws.
May 21, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
How do I know what filter to buy for my Kitchenaide Superba Model# KSCS25INSS00??
Part number 4396841
The filter is located underneath the fridge, and accessed from the front of the fridge.
Mar 04, 2010 | KitchenAid Superba Architect KSCS25INSS...
I have a kitchenaid superba side by side. The wires continually get cut. Does any one know which one controls the water flow to the ice maker? I fixed two tonight and one fixed the crush/cube problem but...
I think I can help you, Thanks, Sea Breeze
Document Type Wiring Sheet
Model Number KSCS25INSS00 Tech Sheet # 2223419
Document Link http://www.servicematters.com/docs/wiring/Wiring Sheet - 2223419.pdf
Model Number KSCS25INSS00 Tech Sheet # W10142175
Document Link http://www.servicematters.com/docs/wiring/Wiring Sheet - W10142175.pdf
Document Link http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Service and Wiring Sheet - W10142175.pdf
If you still need assistance, contact me here at Fixya or through my site HERE or here Sea Breeze Appliance Parts feel free to ask any time, Sea Breeze
Dec 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
How do I remove the refrigerator base grille
On Kenmore Elite: To remove grill front: Open refrigerator and freezer doors. On the curved (outward) parts of the grille cover, place fingers, and press downward. Grille cover will snap off. Reverse steps to snap back in place.22da2f6.jpg
Aug 06, 2009 | Refrigerators
Access to clean coils on kscs25inss00
You need to get a bottle brush they are about 18" long maybe longer and made for getting into these area's to clean the coils. My frig is set up the same way and hate it. Cause when they are that dirty cause's so many things to happen all bad. I have used my air compressor to blow them clean and then chase little dust bunnies around the kitchen. I have been thinking about this same problem for awhile now and bottle brush is the best option for now that I have heard of. ken
Jan 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
Jan 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
