Question about Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb
Electrolux el8807 has no suction - Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb
Wand has no suction when detached from vacuum
The Electrolux vacuum is the source of the suction; when disconnected it will not have suction. Am I missing something here?
Mar 13, 2015 | Electrolux Vacuums
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
My brush piece is corroded
El8807 - call customer service at 800-896-9756 push 1 or 2, then push 3. They sent me a new replacement, no cost. Need your Serial Number so they know date of purchase. 5 year warranty. Best vacuum ever, better than dyson and cheaper by 100%, but the brush stopped working after getting tangled. Called support and they replaced. Great. Cheers!!!
Apr 21, 2014 | Electrolux EL8807A Precision BrushRoll...
I have Electrolux Versatility and have little suction power in the hose part,
Unplug the machine..now if you remove the attachment hose at the body of the vac and feel inside (to the right about an inch) their is a "suction cover" that rotates when the wand is removed (aka using atachments). The cover in your machine is NOT rotating correctly, so it does not get full suction. If you do get some suction from the hose then their is at least a 'small opening' because it has partially rotated. I was able to fix this problem by taking a large screwdriver (1.5 feet long, thick as a pen), inserting it into the small opening (on the suction cover, inside to the right at the top) and forcing the cover down all the way by lifting the screw driver up against the top of the body opening. Seems to have corrected the problem, but may reoccur. If you have NO suction at all then it has failed to rotate whatsoever, and Im not sure how to correct it.
picture of the suction cover part:
http://evacuumstore.com/p-3604-electrolux-versatility-el8502ab-cover-suction.aspx
Nice of that sales lady to provide zero help...
-Steve
May 05, 2011 | Electrolux EL8502 Versatility Bagless...
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
My electrolux is over ten years old now and doe not have much suction. Changed the bar still no suction or very little. What gives? Wjymw
I am the Sales Coordinator with Electrolux, and personally it sounds to me like your machine could use a service check. Your local Aerus/ Electrolux office should be able to help you out with that no problem. If you are having trouble reaching them feel free to call my office (570)326-1731 and ask for Liz. I hope this is able to help you out.
Dec 25, 2007 | Electrolux Guardian Bagged Canister Vacuum
Power unit suction problem
Have you checked the filters?
Nov 15, 2007 | Electrolux Central Vacuum
Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb Logo
166 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
