Question about Canon imagePROGRAF iPF750 Wide-Format Inkjet Printer
Canon imagePROGRAF IPF750 error message 031030031-2F3A
5 Suggested Answers
SOURCE: as to enter SERVICE MODE canon imagePROGRAF iPF700?thanks
Service Mode - With power off, hold paper feed (paper select) button and info button while powering on, release after initializing screen.
Posted on Jul 15, 2009
  • 79 Answers
SOURCE: canon iPF8100
that indicates poor connection of the hard disk connection.
you have to remove and put back the disk and if the problem remains then you have to buy one from your local market and put it.
That might solve your problem
Posted on Dec 29, 2009
SOURCE: Canon imagePROGRAF W8200 InkJet Printer Problem Printhead Error! Turn Power Off!
you need to enter a service mode before the error message pops up. hold down paper source button + online.
that should override the message before it pops up.
go to replace print head selection. or do a clean. it may still be working. let me know if this doesn't work....but at least you can still get past the message now! marty
Posted on Dec 27, 2010
scamper_69
  • 11 Answers
SOURCE: canon ipf750/upgrade firmware
I would first check the linear scale.That`s a small plastic strip ,positioned along the total lenght of the rail.Mind you ,I don`t have a ipf8000.But maybe the systems are the same.The linear scale is under tension ,by a metal spring.Check if the strip is not hanging loose.Also check the strip (linear scale) on dirt or ink splashes.If so clean it with alcohol (that`s what I did on a ipf5000).The scale runs through a slit ,at the back of the carriage.There are light grey patterns on the scale.The sensor on the carriage reads them ,and thus knows the position of the printheads ,with respect to the rest position.Check if the scale runs smoothly through the slit.
Posted on Feb 27, 2013
Error E161-403E
Go onto the Canon Europe site and locate the error codes for your device. It will indicate the type of problem but not how to fix it.
Jul 05, 2016 | Canon imagePROGRAF iPF750 MFP
Je recois un message d'erreur 03800500-2f44
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Apr 20, 2016 | Canon imagePROGRAF iPF750 Wide-Format...
Canon ipf750 error 2F30
Esse error ? relacionado a troca da cabe?a de impress?o.
Nov 07, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
http://mail.davin.be:8888/CANON/BOOK%20IPF/IPF750/ipf750_755-sm.pdf
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Canon ipf750/upgrade firmware
Feb 27, 2013 | Canon imagePROGRAF iPF750 Wide-Format...
Facing 2F1F IN IPF750 MACHINE REPLACED MAIN PCB,PURGE
HELLO ,
IF YOU'VE REPLACED THE PURGE UNITAND STILL CAUSING THE TROUBLE, CHECK THE WIREING!
HOPE THAT HELPS!
Sep 10, 2011 | Canon imagePROGRAF iPF8000 Printer
Canon IPF8100 error code 03130031-2F3A can you please help vicki@westcountry.com.au Thanks
Same error in my ipf755. Canon suggests replacement of carriage (700 eur)...
Feb 16, 2011 | Canon imagePROGRAF iPF8000 Printer
Canon imagePROGRAF iPF750 Wide-Format Inkjet Printer Logo
63 people viewed this question
old marine
old marine
