Question about HP Photosmart C7280 Printer
I have a HP Photosmart D110 and it keeps giving the "memory card error" message. Never used a memory card. I've unplugged, plugged, restarted, etc. Still there. How do I deal with this issue?
5 Suggested Answers
Buschchris1
  • 474 Answers
SOURCE: Memory Card Error
If you can do so, go through the menu options and look for the ' restore to factory defaults option and do it.
Does it have memory ports to plug in or expand memory? if so, try turning off any optionsd to use expanded memory. Also, check the website, there maybe a simple soution available there.
Check for Firmware updates as well.
Posted on Feb 16, 2008
Inky
  • 691 Answers
SOURCE: HP photosmart D7300 series, will
Card format may be incompatible with reader or card may be too large for reader to manage. Try another card in the reader to see if it will read that one. If so you know the card is the problem not the reader.
Posted on Sep 19, 2008
SOURCE: hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Posted on Aug 07, 2009
SOURCE: memoy card error
Im using XP and have the same problem. I have no Memory card in the slot. How do you clear this error?
Posted on Dec 25, 2009
I have an HP C6380 it comes up with the error message "Ink cartridge access door is open" It isn't but I can't override the message. Any help?
Please follow the next steps:
I also tried this:
1-power off unplug power cable wait for a minute
2- Press and hold both "#" and "6" keys Plug-in power chord
3- Be patient Wait for the screen to blank out.
4- Release #6 keys press power on button
Mar 19, 2013 | HP Photosmart C6380 All-In-One InkJet...
Installed a Graphics card EVGA 6200 AGP 8X in my PC HP Media Center PC m370n now keeps showing failure notice
Did you install the drivers for the Graphics Card before you plugged the card into the computer? If not, remove the graphics card and reboot using your old video connection, install the driver then install the card and plug your monitor into the newly installed card. If you still have an issue try booting into safe mode.
Mar 19, 2012 | HP Media Center Photosmart PC (M7160N) PC...
My computer shows pics are downloading to my HP A526 photo printer but the printer tells me to insert memory card. What do I do?
Make sure that the printing action is selected only for the right configuration and setting including the format and file type. If the file is too large to be printed it can show up as a error or an insufficient memory to back up. Alternatively you can check with another PC or reinstall the printer once again.
Dec 14, 2011 | HP Photosmart A526 photo printer
I put 2 new printer cartridges in and got the effor Oxc18a0101. What should I do? My printer is an HP Photosmart D7160. I've looked at some solutions on line, but they refer to typing numbers,...
Hi Karen, This likely is either due to Bad/Expired Printhead or it could be defective printer ( hardware failure ). However you can give it a try. Follow the steps below and it should solve the problem, else we need to consider it could be defective Printhead or printer hardware failure.
The Photosmart D7160 does not has "*" and "#" because it is not a fax capable printer.
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
The error message 0xc18a0001 "Ink System has Failed" is now gone
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 17, 2011 | HP Photosmart D7160 InkJet Printer
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
Cant transfer pic from Hp Photosmart 415 camera to computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 10, 2009 | HP Photosmart M415 Digital Camera
Hp photosmart 2610 won't read my sandisk ultra memory card
Feb 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
Memory Card
Try taking the SD card out then plug the camera into the p.c then format the internal memory.
Nov 13, 2007 | HP Photosmart M415 Digital Camera
HP Photosmart C7280 Printer Logo
361 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
