How to clear error code c-1450 on minolta di552
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Jan 09, 2017 | Konica Minolta Bizhub C280 Color Copier /...
C-0072 is showing on my Konica Minolta di552 please help to remove this error
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it is damaged you get a code. If this does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Mar 06, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
How to solve code C0510 on konica minolta di552
Open the front door upper left access cover, open press trouble reset if the code comes back do not reset as this deals with fuser can catch on fire will ruin perfectly good day
May 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c 145 E ON MINOLTA di 552
Sir/Mam the you have the problem under the Di183 but you have di552 check the 183 no such code Sure it is a Di 552 and code is c145E?
Apr 11, 2014 | Minolta DiALTA Di183 Copier
ERROR CODE C 145 E FOR MINOLTA DIALTA
Sir, You have this problem listed under Di183 , Di3010 and Di552 First two have no code C145E Never heard of a Di552
Please give the Model number and code again does this have Fax option?
Apr 11, 2014 | Minolta Di3010 Copier
WHERE IS THE DEVELOPER UNIT SITUATED IN A MINOLTA DI552 COPIER
Open the front door release the lever. To your upper right is the drum cartridge the developer section is include in the cartridge to black bolts hold the drum cartridge in place. When replace the developer DO NOY USE A VACUUM Cleaner the static electricity can destroy the sensor at the bottom of the developer holder.
Sep 05, 2013 | Minolta EP1030/1030F CS/PRO Copier
Minolta di552 copier error message c0210
Directly below the drum section is a assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire might be broke, or has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. If it comes back have qualified tech look at it. Try web site below for place to start for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 16, 2012 | Minolta Office Equipment & Supplies
We have a Minolta Di552 copier with an error message C-0F24 on the display panel. What is the problem?
Has the developer been replaced? If not reset counter for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items then the copier will adjust certain voltages to certain items such as the drum and developer system as those they are new because you reset the counters when in fact he developer is old and so might be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared !ST!!!!!!!!!!!!!!! and was the required F8 checked run? after installing. Also was the drum removed and the sensors cleaned by brush NO Vacuum cleaner. Static Electricty can destroy the the sensors.
Dec 22, 2010 | Minolta DiALTA Di350 Laser Printer
My Minolta CF 1501 color copier shut down with a malfunction code C0060, I cleared the paper pileup and need to know how to clear code.
It is a fuser motor error. Check that. If there is a problem with that motor, unless you clear the actual problem the error will not go away.
Aug 02, 2008 | Minolta Office Equipment & Supplies
k24674
jasbo
jasbo
