Do we require a wia driver for fi6130z
I have written an application in vc++ to scan from fi6130 using wia. This application works ok with fi6130 but gives error with fi6130z. The problem occurs with the function item.transfer. I have loaded all the drivers supplie d with fi6130z. What could be the problem?
Benimur
  • 6966 Answers
SOURCE: which program do i use to transfer the scanned image too?
Sounds like the CanoScan is looking for a photo enhancing/utility program. Programs for this purpose are Adobe PhotoShop, PaintShop Pro, ACDSee, or even the simple Windows Paint.
Additionally, the CanoScan Toolbox might have a basic photo utility program. Normally basic photo utility programs like this are included in the CD installer of a scanner, a digicam or even most color printers.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 02, 2007
Nitrotrike
  • 589 Answers
SOURCE: epson scan application won't open
Do you mean the old powerbook has the same OS as the new one, or the same epson software version?
In any case, this is all I found on it:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58609&prodoid=63060805&infoType=Downloads&platform=Macintosh
Posted on Jan 11, 2008
Pterocarpous
  • 202 Answers
SOURCE: Tvichw32 Driver Open Error
Hello Aunt Pat
(01) Is this scanner "new" to the computer it is installed on now (where you're experiencing these issues)?
(02) Did this problem show up w/out apparent cause or relation to any recent changes on your system (e.g. New hardware or software installed, updated, upgraded or removed; system crash; computer repair; etc.)?
(03) Did the problem appear soon after a change to your system? (see above examples)
There are many references to this issue on the Internet. I've listed a few here. You can find many more, if you like, by performing search engine queries.
THIS links to a Roxio forum thread regarding this issue. (Even if you aren't using Roxio software, the information here could be relevant to your issue.)
THIS link will explain a bit about what TVICHW32 driver is.
I'd reinstall the ASPI drivers. A driver file may have become corrupted. (Assuming you'd been using this scanner successfully on this system until recently.)
You can find links for Adaptec's ASPI drivers on their web site HERE. They also have an ASPI version checker you can run to find out what verison is installed on your computer.
** Please, post back here w/ answers to
** these questions and the results of what
** you've tried. We may need to go back
** and forth a few times. We WILL continue
** to work w/ you until your problem is re-
** solved.
** Just be sure to not rate the experts' "sol-
** utions" until that time. Once you do,
** the problem will be closed and we'll no
** longer be able to assist you.
** Thank you @:)
Posted on Apr 10, 2008
SOURCE: driver for VUEGO Scan Brisa 340p under winxp
i need software for the scanner VUEGO SCAN BRISA340. THANKS.
Posted on Nov 16, 2008
SOURCE: TWAIN Driver Error
If the windows image acquisition service is running, stop/disable it and see if this helps with the apparent concurrency problem.
Posted on Apr 16, 2010
How can I scan using USB cable?
Unfortunately, FS-6025MFP does not support scanning via usb cable. All scan functions are possible using only network cable.
See the picture below.
May 14, 2015 | Kyocera FS-6025MFP Laser Multifunction...
After scanning a document, a line is on document
Hello Norma,
Are the scan settings correctly specified for the scanning application software used? Check if interface cable are correctly connected.When the error occurs on ADF front, clean the glass inside of Base Unit. When the error occurs on ADF back, clean the glass of the Upper Unit.Check if any dirt get on the white reference sheet?
Also, check the mirror of the OPT Unit dirty, clean the mirrors.
Check the connector and check any cables are damaged,if so, then replace the damaged cables.
If the above doesn't help, then the issue may be due Optical unit or Control PCA problem. hence, you may have to seek the help of Fujitsu scanner technicians for rectification.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 16, 2013 | Fujitsu Fi6130z Sheetfed Scanner
Code:7,202,15- My Canon MX-870 (Twain) gives me this error code when I try to resizew in B/W or grey scale. No problem in color.
"Internal error occurred. Scanner driver will be closed. code 7,202,15"
Received the above error while inserting scanner image using MS Word with Canon printer/scanner Pixma 439.
The solution is via the following MS Word software choices:
From Word tool bar choose: INSERT/PICTURE/FROM SCANNER/then one of two choices, either: WIA-WIA Canon MX430 Series, or choose CUSTOM INSERT (Preferable).
R
Aug 21, 2012 | Canon PIXMA MX870 Wireless Office...
Scans two pages and stops midway through the next page. This just started happening. I scan in bulk, archiving payables. I've tried restarting both my computer and the documate and problem still continues....
I've seen this issue happen when the wrong driver was being used. When you install the documate, it installs 2 drivers. The WIA driver (windows acquisition driver) and the TWAIN driver. Make sure that you are using the TWAIN driver.
Mar 04, 2011 | Xerox DocuMate 152 Pass-Through Scanner
I have a Canon 4200F scanner and recently purchased a new computer with Windows 7 that is 64 Bit. When I try to use the scanner get a message that I need a WIA driver to use this device. Can you please...
Hi bjgestel !
This means there is no more support from HP for your unit under Windows 7 but Windows has a compatible driver included in it's system ( WIA ) .
The scanner should run smooth but with some restrictive functions . Normaly , it should run without having installed the HP XP driver/ sofware . If this not your case , there is a workaround after you installed the XP driver and made sure installation was successfull . The scanner will need to run with a third party application . Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP's software, program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
Good luck !
fanaudi .
Feb 22, 2011 | Office Equipment & Supplies
How to run hpscanjet 4470c on windows 7?
Hi and welcome ned92 !
Solution one:
You can get your unit working in WIA mode if you can follow this :
make sure your XP ( yes XP ) driver is correctly installed .
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP PrecionScan Pro , program will hang .
Note : no slides or negatives scans possible in WIA lode but the rest works .
solution two :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
Have a nice day ,
Best regards .
fanaudi .
Feb 14, 2011 | HP Scanjet 4470c Flatbed Scanner
Trying to load CanonScan N124OU onto Windows 7 and get error message "there is no application registered for this event"
canon scan n1240u will work on Win7
here's how:
go to this site: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
click "Drivers and Software" then select OS "Windows XP" then download "WIAdriverN670UN676UN1240U.EXE"
Install the WIA driver on your Windows 7 OS and used only mspaint to capture image on the scanner
TWAIN doesn't work on Win7 but WIA still doesGood Luck!
Dec 06, 2010 | Canon CanoScan N1240U Flatbed Scanner
Canon ImageClass MF6540- works fine for printing, but scanning complains connection problem on Dell Dimension E521. However my other Dell Dim 9200 computer runs fine for both printing and scanning. What...
Need some clarification about the error.
We need to know the exact error.
Generally all the scannars use TWAIN technology which bridges the scanner with WIA(windows imaging aquisition).
We need to know if WIA which is a part of the operating system is working. For diagonasting we can try using teh scanners and camera wizard from control panel or we can use mspaint even.
If WIA is working in that case the problem may be with the registry values of the scanner.
WE can try making a new user account with admin rights and then we can try installing the scanner. We can even try using Revo uninstaller for uninstallation of the scanner because it will remove all the entries from registry, then we can try scanning.
BEST OF LUCK.
Feb 11, 2010 | Canon ImageClass MF6540 Copier
Can't scan image to word or photo gallery
First thing to do is try to check if your windows XP is a 32 or a 64-bit. You can do this by right clicking the mouse on My Computer icon and then left click on properties. Now try to load the right and updated driver. If it still won't work. Go to Control Panel>administrative tools>services>scroll down and look for WIA ( Windows Image Acquisition). when you double click on it you should see it it is running, stopped, make sure that it is started. If still won't work try using other application like paint.
Sep 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have the Acer S2W 3300u scanner and although I installed the drivers for Windows XP, it shows the error message "EXE application has encountered a problem and needs to close. We are sorry for the...
I have the same scanner and the drivers that came with the scanner don't work. Windows XP uses a generic twain driver that works, also most pictures viewer like XnView or Picasa uses the same. I'm using one called Wia-flatScanner_21 1.0(32-32).
Apr 01, 2009 | Acer Scan to Web 3300U Flatbed Scanner
226 people viewed this question
jasbo
jasbo
